Results 1 to 12 of 12
Thread: Flatirons Tuning Engine and Transmission parts for your 818
    FlatironsTuning's Avatar
    Mar 2014
    Boulder Colorado
    We are a new vendor here, but we have all ready helped our a few people with their 818's, and maybe we have something for you too.
    We have been specializing in Subaru performance for a long time now, and we have a huge amount of engine and transmission parts from pistons, cranks, blocks, bearings to gear sets, differentials, etc. I'll post a few things here, and if you don't see something that you need, let us know and we probably have it. We also have a ton of parts up on our web-site www.flatironstuning.com
    Thanks for looking, and please feel free to ask us any questions you may have!
    First up, Hybrid swaps. We have put together 3 different levels of kits if you want to put a 2.5 shortblock in your car with 2.0 heads.
    Basic Hybrid Install Kit
    Doing a budget EJ257 rebuild in your WRX? This is the kit for you. This kit assumes that anything that can be re-used from your 2.0L WRX setup is in good condition. It includes everything that is absolutely necessary to replace to get the EJ257 swap running in your WRX.
    You may need to replace other parts due to wear, but this kit includes everything that is totally necessary.
    It includes:
    -- OEM Valve cover gaskets
    -- OEM Intake manifold gaskets
    -- OEM Water Pump gasket
    -- OEM Oil pump seals and gasket
    -- Either an OEM STi or Cosworth 1.5mm Head Gasket set
    Click here for your Basic Hybrid Install Kit from $155.58
    COMPREHENSIVE 2.5L HYBRID SWAP INSTALL KIT
    The next step up from the basic kit, the comprehensive kit includes all the gaskets required for you to do a complete resealing of your engine during a hybrid swap. It also includes the Cosworth 1.5mm Head Gaskets (Part # 20002145), designed to lower compression when using the 2.0L heads.
    This kit does not include any hard parts, only gaskets, so like the Basic kit assumes that all mechanical parts are re-usable.
    Subaru is not including Valve Cover Gaskets any longer in the 2002 MGK, and they have removed the Half-Moon seals from both kits as well. Because we feel these are important parts that you will need, we have now changed our prices to include them so you will not need to purchase them separately.
    Click Here for your Comprehensive Hybrid Install Kit from $433.55
    MASTER 2.5L HYBRID SWAP INSTALL KIT
    Save by buying everything for your EJ257 swap in one place!
    This kit includes everything that we recommend to do an EJ257 hybrid swap the right way.
    This ensures you have peace of mind, knowing all the vital components supporting your new block are also new, or upgraded. Also, all of these items need to be removed during the swap anyways, so it is a wise choice to do them now while the engine is out of the car, as opposed to wrestling with it down the line when you need to replace the old water pump you re-used.
    The OEM kit includes:
    -- All gaskets to reseal the entire engine (Comprehensive Hybrid install kit)
    -- Cosworth 1.5mm Hybrid swap head gaskets
    -- New OEM Thermostat
    -- New OEM Water Pump
    -- New OEM Timing Belt Tensioner
    -- Cosworth Kevlar Timing Belt
    -- New OEM 11mm Oil pump with new bolts from the 2009 STi or OEM Subaru 10mm pump with new bolts
    The Gates Kit includes:
    -- Gates Racing Belt Timing Kit, which includes new tensioner, all idler bearings, water pump, and Gates Kevlar Racing Belt
    We can also put together a custom kit with the exact parts you want. It is no problem for us to switch the 11mm Oil Pump for a Cosworth Blueprinted Pump, ditch the Cosworth head gaskets for the OEM ones, or add on a set of ARP head studs, timing belt idler pulleys, or Group-N Engine Mounts. We have anything you need right here.
    Click Here for your Master Hybrid Install Kit from $810.97
    We have short blocks in stock as well:
    We stock the 04 - 08 STI blocks, the 09+ STI blocks, EJ255 blocks, and EJ20 blocks as well.
    Click Here for your 2009+ STI Block for $1800.00
    Click Here for your 2004 - 2008 STI Block for $1800.00
    Click Here for your EJ255 block for $1800.00
    Click Here for your EJ20 block for $1850.00
    If you are looking to re-build your engine, we have a Rotating Assembly Kit with just about every option that you could need
    Searching for the right parts to build your EJ257 block? Look no further. Flatirons Tuning has now assembled our most popular forged internal setups into ready-to-build kits.
    These do not come assembled. We can arrange to have the kit assembled before shipment for additional charge, however, this kit is designed for the customer who is planning to have the block assembled themselves.
    This rotating assembly includes everything you will need to build your existing EJ257 block or a pair of our blank case halves. Save money and time by buying all the parts together from one place!
    The kit includes:
    - OEM Heat-Treated EJ257 Crankshaft
    - ACL STD Race Bearings
    - Eagle Rods
    - Your choice of either CP or Wiseco pistons, with Rings
    If you are having your block machined and need an oversize piston, or if you want Cosworth bearings in a size other than the standard Size 1, just send us a PM to discuss your options.
    Please note the new lay-out below. The basic Rotating assembly will be as listed above. If you want to up-grade any items, just add them to your cart after you have selected the base rotating assembly.
    Click Here for your Flatirons Tuning Rotating Assembly
    303.402.5142
    Your source for any Subaru parts that you may need to build your 818 from engine parts to gear sets, etc. We have what you need.
    Mar 2014
    Boulder Colorado
    We also just these in, and they look pretty darn good, so I'll put them up here at the top:
    Kinugawa Ceramic Coated Equal Length, and Unequal Length Headers:
    KINUGAWA CERAMIC COATED SUBARU EQUAL LENGTH EXHAUST MANIFOLD
    Application SUBARU EJ25 Impreza
    This kit fits:
    2002 - 2005 WRX 2008 - 2014 WRX
    2004 - 2014 STI
    2006 - 2007 WRX can fit, but may require installing the 02 - 05 WRX oil cooler.
    These headers also require an STI style oil pan.
    Pipe diameter - Main Pipe (4 pipes) : 42.7mm (inside / Outside)
    - Collecting Pipe (2 pipes) :45mm
    - Up-Pipe (1 pipe): 60mm
    Material
    - Wax SS304 Stainless
    (Bend in shape from one pipe / No welding)
    Kinugawa Part # 323-02049-003
    This header is Ceramic Coated with a special Satin ceramic Coating.
    Satin Ceramic Exhaust Coatings are the most advanced exhaust system coatings available. They are a very durable ceramic-reinforced coating available. When properly applied, it becomes the most effective thermal barrier coating available, increasing performance while extending component life, and has been tested to over 2000° F without lifting, cracking or flaking.
    Click Here for your Ceramic Coated Kinugawa Equal Length Header - $771.55
    KINUGAWA CERAMIC COATED SUBARU EXHAUST MANIFOLD UNEQUAL LENGTH
    This kit fits:
    2004 - 2014 STI
    This kit includes:
    - 1 x Exhaust manifold with Up Pipe
    - 2 x Stainless Gasket (header to engine)
    - 1 x Stainless Gasket (Turbo to Dump Pipe)
    - 1 x Stainless Gasket (Turbo to Up Pipe)
    - 1 x Stainless Gasket (Header to Up Pipe)
    - 3 x Mid Steel Stud kit ( Header to Up Pipe)
    - 5 x Stainless Stud kit ( Turbo Inlet or Outlet)
    Material
    Wax SS304 Stainless
    Pipe Spec.
    - Pipe Material: Stainless SS304 / 2.5mm thickness
    - Flange Type : LostWax
    - Connection Type: 4-2-1
    - Main Pipe ID Dia. : 39mm
    - Collection Pipe ID Dia. : 57mm
    - Up-Pipe ID Dia. : 57mm
    Kinugawa Part # 323-02049-002
    This header is Ceramic Coated with a special Satin Ceramic Coating.
    Click Here for your Kinugawa Ceramic Coated Unequal Length Header - $786.75
    We also keep ASF Machine Balanced EJ257 Heat Treated Cranks in stock
    ASF Machine Balanced EJ257 Crank
    We have had a number of requests for a precision balanced crank, and we are proud to announce that we now have one. We are working with ASF machine, and having them balance the stock heat treated cranks for us, and they are now available.
    The crank's are usually balanced to within .3 - .5 grams.
    They are on our shelf ready to ship, and at most would be about a week out. But we are working with ASF to make sure that these are readily available.
    Flatirons Tuning part # is 12200AA330-BAL
    Click Here for your ASF Machine Balanced EJ257 Crank - $515.00
    We stock the factory heat treated cranks as well!
    OEM 2011+ SUBARU STI HEAT-TREATED CRANKSHAFT
    This is the Heat Treated crankshaft out of the 2010 Subaru WRX STi EJ257.
    Heat Treating hardens the surface of the crank, which prevents scoring caused by a piece metal getting stuck between the bearing and the crank.
    By increasing the hardness of the crankshaft surface, any material which gets caught between the new surfaces is simply ground down and filtered out through the oil, potentially preventing bearing failure.
    This is a brand new part, straight from Subaru!
    The Subaru Part # for this Heat Treated Crank is 12200AA330, superseded from the 12200AA430 which was Nitride Treated.
    Click Here for your OEM Heat Treated Crank - $315.00
    303.402.5142
    Mar 2014
    Boulder Colorado
    We Keep Legacy Gear Sets for the 2002 - 2007 WRX transmissions in stock
    This is the OEM Main Shaft, and 1st through 4th gear that came in the 5-Speed manual transmission in the 2005 – 2008 Legacy GT.
    This set is available with either the Main Shaft and 1st and 2nd gear, or the Main Shaft and 1st through 4th gear. This gear set can be retrofitted into most Subaru 5-speed gear sets, but depending on the year of your transmission, you would need additional parts.
    We now offer the 1-4 gear set with installation kits for the 2002 - 2007 WRX. Each kit is slightly different, but they all include all the parts that are required for installation. There may be other parts that need to be replaced due to wear, such as bearings and synchros. If you need any other parts, let us know.
    All of the install kits include a new speedometer gear, but WRX's with a 3.7 final drive will have a slight speedometer discrepancy.
    Professional installation is very strongly recommended. If this gear set goes into any car other than it was originally designed for by Subaru, there is no warranty for strength expressed or implied.
    Also, because of the number of issues that can arise due to improper installation, this gear set is not returnable once any of the parts are installed, and we will not warranty any damage to the gear set or any other parts that is the result of improper installation.
    For more information about the Legacy GT Gear set, and other Subaru Gear Sets, please click here.
    The Gear ratio’s of this transmission are:
    1st: 3.166
    2nd: 1.882
    3rd: 1.296
    4th: 0.972
    5th: 0.738
    Click Here for your Legacy GT Gear Set - from $694.00
    STI RA CLOSE RATIO GEARSETS
    Assembled by RalliSpec, the close ratio gears from the STi RA feature strengthened and hardened components for improved reliability of the 5MT in modified Imprezas. The gearsets have REM-treated 1st-4th gears for even further improvements in reliability at high power levels. Each gearset includes all necessary gears for installation including a custom speedometer gear (3.9 final drive ratio only).
    Please call for availability.
    Now REM Treated for increased strength.
    Professional installation is recommended.
    JDM STI
    1st-3.166
    2nd-1.882
    3rd-1.296
    4th-0.972
    5th-0.738
    JDM STI-RA
    1st - 3.083
    2nd - 2.062
    3rd - 1.545
    4th - 1.151
    5th - 0.825
    USDM WRX
    1st - 3.454
    2nd - 1.947
    3rd - 1.366
    4th - 0.972
    5th - 0.738
    This kit contains the following:
    STI RA Main Shaft
    STI RA 1st Driven Gear
    STI RA 2nd Driven Gear
    STI RA 3rd Drive Gear
    STI RA 4th Drive Gear
    STI RA 3rd/4th Driven Gear Cluster
    STI RA 5th Drive Gear
    STI RA 5th Driven Gear
    1st Gear Synchro (baulk ring)
    Lock Nut, Main Shaft
    Lock Nut, Pinion Shaft
    Lock Nut, Driven Shaft
    Oil Seal, Main Shaft
    Custom Steel Speedometer Gear
    (Calibrated for 3.9 Final Drive)
    Case Gasket
    You must select the correct Installation kit for the year of your car. If you are not sure what year your gear set it, you need the 02 WRX Install kit.
    If you do not have Flatirons Tuning build your transmission for you, we do not offer any warranty on the parts due to the number of issues that can result from improper installation.
    Click Here for your STI RA Gear Set - from $2037.49
    STI Version 6 STANDARD RATIO GEARSET
    Assembled by Rallispec, the STi standard ratio gears feature a 5th gear that is identical to the stock WRX for those wishing to maintain the same highway performance. However, these gears provide improved reliability of the 5MT through similar hardening and strengthening features as found on the STi RA set listed above.
    Now R.E.M. treated for increased strength.
    This Kit Includes:
    - Main Shaft
    - 1st Gear Driven
    - 2nd Gear Driven
    - 3rd/4th Gear Set
    - 5th Gear Set
    - Main Shaft Lock Nut
    - Output Shaft Lock Nut
    - Pinion Shaft Lock Nut
    - Transfer Case Gasket
    - Front Main Shaft Oil Seal
    - Custom Steel 3.9 Speedometer Gear
    - Installation Kit for Correct year Car
    Professional installation is strongly recommended, and you MUST order the correct installation kit for your car. If you are not sure what year transmission you have, you need to order the 02 Installation kit.
    JDM STI
    1st-3.166
    2nd-1.882
    3rd-1.296
    4th-0.972
    5th-0.738
    JDM STI-RA
    1st - 3.083
    2nd - 2.062
    3rd - 1.545
    4th - 1.151
    5th - 0.825
    USDM WRX
    1st - 3.454
    2nd - 1.947
    3rd - 1.366
    4th - 0.972
    5th - 0.738
    Click Here for your STI Ver. 6 Standard Ratio gear set - from $1408.71
    MODENA FRONT TBD FOR THE 02 - 07 WRX
    Modena is one of Australia's premier manufacturers of Motorsport Gears and Differentials.
    This is Modena's Torsen Style Torque Biasing Front Differential for the 2002 - 2007 WRX. This replaces the factory open differential, and will behave much like the factory LSD that is in the rear differential, or like the front LSD that comes in the STI from the factory.
    Modena's Torque Biasing Differential will provide improved traction under acceleration, but will open, or "Unlock" under deceleration as soon as you lift your foot off the accelerator. This is ideal for a car that is driven on the street, or at the track or Auto-X course because it will give you improved traction through the corner, and will help reduce understeer.
    The reason that this differential is not called a "Limited Slip Differential" is because it doesn't "lock-up" when the wheels begin to slip, which means that both wheels are receiving the same amount of torque and turning at or near the same speed.
    Instead, The Modena Torque Biasing Differential will transfer torque between the left and right wheel in order to make sure that 100% of the torque that is sent to the front axle is distributed between the two wheels. In other words, if one wheel is receiving 60% of the torque, this differential will make sure that the other 40% is sent to the other wheel.
    This results in improved traction for a better exit from the corner, without inducing any understeer, which a "Locked" Limited Slip Differential has a tendency to do.
    Professional installation is strongly recommended, and this diff comes with stub-axles all ready installed, for ease of installation.
    This Modena Torque Biasing Differential is In Stock and Ready To Ship!
    Click Here for your Modena 5MT front TBD - $1250
    If you are looking for a clutch, you have come to the right place. We stock a number of Exedy Clutches, including their OEM replacement kits, and ACT and Clutch Masters clutches as well. We also stock the OEM flywheels and Exedy Light Weight Flywheels too!
    Exedy is the manufacturer of the OEM (original equipment) clutch that comes in the Subaru WRX. If the time has come to replace your clutch, buying this kit directly from the manufacturer is a great way to get a great clutch at a great value. This kit is identical to the clutch that you would get from a Subaru Dealership, but it is less than half the price.
    This Kit includes:
    Exedy Pressure Plate
    Exedy Clutch Disk
    New Pilot Bearing and Throw-Out Bearing
    Flywheel not included.
    The 06+ clutch will also work for the Legacy GT models if you use the 06+ WRX flywheel
    If you aren't sure which kit you need, remember that the transmission determines the clutch. So if you are using the transmission out of a 2006+ WRX, you need the clutch for a 2006+ WRX.
    In stock and ready to ship.
    Click Here for your Exedy OEM replacement Clutch Kit - From $183.73
    OEM SUBARU FLYWHEELS FOR WRX, STI, AND LEGACY GT
    This is a brand new OEM Subaru Flywheel for the WRX, STi, or Legacy GT
    These pieces are brand new straight from Subaru!
    Please ensure you choose the correct flywheel for your application. If you are not sure which flywheel you need, give us a call or email us with the last 8 digits of your donor car's VIN number and we can make sure you are ordering the right piece.
    Click here for your OEM Flywheel - From $239.96
    Mar 2014
    Boulder Colorado
    EXEDY STAGE 1 HEAVY DUTY ORGANIC CLUTCH FOR THE 2002-2005 SUBARU WRX
    This is a brand new Exedy Stage 1 Organic Heavy Duty Clutch for the 02-05 Subaru Impreza WRX 2.0L.
    This clutch is the Heavy Duty variant, which increases the torque capabilities to 319 ftlbs wheel torque, over the standard Stage 1 Organic Clutch's 278 ftlbs wtq.
    This will also fit the following models:
    -- 04-05 Baja Turbo
    -- 04-05 Forester XT
    EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of Exedy's clutch discs have spring center dampers to reduce drivetrain shock.
    Perfect as a replacement clutch if you have modified your vehicle's power output.
    Includes alignment tool and throw out bearing.
    Exedy Part # -- 15802HD
    Click Here to order your Exedy Stage 1 HD Clutch for the 2002 - 2005 WRX - $487.86
    EXEDY STAGE 1 ORGANIC CLUTCH 06+ WRX & '05+ LEGACY GT
    Exedy Racing clutches with organic friction materials use only premium friction materials that are resistant to slippage and burst. Increasing clamp loads give the necessary capacity to handle modified engines. The preferred clutch for street and light horse power track use.
    The drivability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All Exedy clutch discs have high capacity spring center dampers to reduce the drive train shock and impact.
    Engine Code: EJ25T
    Torque Capacity: 287 Ft/Lbs. wheel torque
    Exedy Part # 15804
    For use on a Legacy GT, you must use a 2006+ WRX Flywheel. This kit will not work with the OEM Legacy GT Flywheel.
    Click Here for your Exedy Stage 1 2006+ WRX Clutch Kit - $464.52
    EXEDY LIGHTWEIGHT FLYWHEEL FOR THE 2002-2005 SUBARU WRX
    Exedy Racing Flywheels are made from solid one-piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel, and have the possibilities of separating from the flywheel.
    The steel insert on alloy flywheels also has the possibility of warping which could alter the set clamp load of the clutch cover and effect disengagement. This could cause the flywheel to explode due to two different expansion coefficients (aluminum flywheel pressed on steel ring gear). Exedy steel billet and forged steel flywheels have passed engineering tests to 15,000 rpm. They are guaranteed to be explosion proof at that rpm.
    Engine Code: EJ20T
    Weight: 12.7 Lb.
    Exedy Part # FF01T
    Actual Flywheel may be other than pictured.
    Click Here to order your Exedy Lightweight Flywheel for the 2002 - 2005 WRX - $284.16
    EXEDY LIGHTWEIGHT FLYWHEEL FOR THE 06+ WRX
    Exedy Racing Flywheels are made from solid one-piece billet chrome moly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel, and have the possibilities of separating from the flywheel.
    Engine Code: EJ255T
    Weight: Aprox. 12.7 Lb.
    Exedy Part # FF501
    Click Here to order your Exedy Light Weight Flywheel for the 2006+ WRX - $317.20
    CUSCO HEAVY DUTY MOTOR AND TRANSMISSION MOUNT KIT FOR WRX, STI, AND GC8
    Specially designed by Cusco for each application, these mounts are completely new. These are not cheap mount inserts; these are completely custom designed, complete mounts for the WRX. Perfect for those customers looking to drastically reduce engine movement.
    These differ from the OEM and Group-N Mounts in that there are two metal plates, which are connected during installation with bolts through the stiffer rubber compound bushing.
    This kit includes both lower engine mounts and the 5-speed transmission mount, and is sold as a kit only.
    STi 6-speed customers will not be able to use the 5-speed transmission mount portion of the kit.
    Click here for your Cusco Engine Mounts - $318.00
    STI HARDENED GROUP-N ENGINE AND TRANSMISSION MOUNTS
    These Engine and Transmission mounts are made by Subaru Technica International to replace the stock parts. They are made using stiffer rubber and plastic to reduce movement of the engine and transmission under hard acceleration and braking. These are strongly recommended for highly modified engines.
    Each part is available separately, or you can save with our Group-N Engine Mount Kit which includes all three Engine Mounts, or our Complete Group-N Kit which includes the Transmission Mount as well.
    Transmission Mounts are now available for both the 5 Speed and 6 Speed Transmissions!
    Professional installation is strongly recommended.
    Please note that the 2008 - 2012 WRX require 2 additional nuts per side to install the Group-N Lower Engine Mounts (total of 4). Part # 902380007
    All Group N Engine Mount Kits now include free shipping!
    Click Here for your Subaru Group-N engine Mounts - $235.00 for the full 4 piece kit!
    Mar 2014
    Boulder Colorado
    JDM STI TGV DELETES
    Japan has different emission standards than we do here in the states, and so most of the STI’s come without Tumbler valves from the factory.
    These are the JDM STI TGV’s for both top-feed injectors, and side-feed injectors. They will fit all USDM Turbo EJ Series Engines from 2002 – 2006 without modification. They can be installed on 2007+ USDM Turbo EJ Series Engines by slightly modifying the center bolt holes.
    Also, please note that removing the TGV’s will require a tune on all cars, and may interfere with your car’s ability to start when it is very cold.
    Top-Feed TGV Subaru Part # 14001AB441
    Side-Feed TGV Subaru Part # 14003AB931
    Sold in pairs only.
    Click Here to order your JDM TGV Deletes - $259.60
    Cusco 1.5 Way Front Limited Slip Differential for the Subaru 5MT
    Three ways to set your CUSCO limited slip differentials: 1 way, 1.5 way and 2 way.
    1 way LSD: Specially suited for front wheel drive cars and AWD front axle cars. Activates under acceleration, and acts as a true LSD when the throttle is off. This CUSCO 1 way LSD will improve lap times without a doubt.
    1.5 way LSD: Activates under acceleration while the under-steer under deceleration is less than on a 2 way LSD. Recommended for those who have a hard time with under-steer.
    Two way LSD: Recommended on rear wheel drive cars and AWD rear axle cars. Activates on both acceleration and deceleration. Recommended for those who prefer aggressive driving and big angle drifting.
    The Low Initial TYPE RS
    Low power loss means better lap times for even the mild tuned of cars
    Chattering is kept low
    Improved durability as clutch plates are low pressured
    The LSD efficiency is higher with smoother oil flow between plates.
    The Benfits
    According to CUSCO'S in house research, initial torque is 50 to 70% lower compared to the conventional cone plate type LSD enabling lower drive friction and better response.
    The Type RS's Durability
    Special precision springs, set in the pressure plate, assure steady coil movement
    Clutch plates do not stick together like convetional cone plate type LSDs. Therefore less clutch plate wear or deterioration occurs.
    The Benefits
    The Type RS LSD had proved to be capable of competition use in the All Japan Gymkhana Championship without overhauling a single time during the season. With all drivers and teams finishing with good or championship reuslts at the end of the season.
    Uncompromising Characteristics of the Type RS LSD:
    Reacts to throttle work directly
    Transfers high power without slippage
    No clutch slipping in 0-400 meter accelerations (1/4 mile competition)
    Transfer steady power in long drifts
    Maintaining Stability And Performance
    Cusco oil through system enables stability in high performance LSDs.
    CUSCO's unique Oil Through System enables better oil flow inside the LSD for better efficiency. The casing made from CUSCO's unique technology allows the oil to flow from the wide end, to the pressure rings, then to the MZ clutch plates for efficeint lubrication. Making the LSD more stalbe and durable!
    This was only possible with CUSCO's unique technology in manufacturing chromoly steel casing and gears that enabled a higher level of durability and a better flow of oil due to the large oil openings.
    All Differentials come set at 100% lock-Up. They can be set up at either 60% or 80% lock-up for an additional charge.
    Click Here to order your Cusco Front LSD - $1330.00
    If you want to change your Final Drive with your 818 Conversion, we have 4 options for you!
    This is a brand new Subaru Ring and Pinion Gear Set for the 2002 – 2014 Subaru 5MT transmission.
    Through the years, Subaru has made 4 different ratios for this front ring and pinion gear, and depending on your application, it may be advantageous to swap out the stock ring and pinion for one of these other options.
    Keep in mind that if you are using the transmission in an All Wheel Drive application, you will need to consider the transfer gear ratios, and rear differential ratios when changing the front differential ratio, otherwise serious drivetrain damage could result.
    The available options are:
    4.44:1
    4.11:1
    3.9:1
    3.7:1
    If you are not sure what would be best for your application, or of what other parts you may need to make this work, please contact us before placing your order.
    Click Here to order your new Front Ring and Pinion Gear Set!
    Mar 2014
    Boulder Colorado
    We now have Company 23 Tools in Stock! They offer a wide variety of Subaru specialty tools that will make it much easier for you to work on your engine, change your timing belt, etc.
    Here is a link to their full line of tools that we stock:
    http://www.flatironstuning.com/m-151-company-23.aspx
    Remove both the intake and exhaust cam sprockets without damaging the cam or the sprocket
    Perfect tool for cam seal renewal, cylinder head removal, or motor tear downs
    3-piece welded construction handles the torque
    High precision laser cut construction fits perfect
    Long integrated handle makes it easy for one person
    Comparable to factory tools #499207400 and #499207400-A
    Works with:
    02-07 Subaru Impreza WRX STI (exhaust cams only)
    02+ Subaru Impreza WRX (08+ WRX exhaust cams only)
    04-08 Subaru Forester XT (exhaust cams only)
    05-10 Subaru Legacy GT (exhaust cams only)
    05-10 Subaru Outback XT (exhaust cams only)
    05-06 Saab 9-2X
    04-06 Subaru Baja
    Click here for your Non-AVCS Cam Wrench - $49.95
    Locks the LH side cam sprockets from turning when the timing belt is removed
    Prevents cam sprockets from spinning when belt is removed and eliminates potential valve damage
    Saves time! Makes timing belt changes faster and easier especially when done with one person
    Strong neodymium magnets ensure the tool stays in place even if bumped
    Curved plate allows easy viewing of sprocket timing marks
    Works with:
    02+ Subaru Impreza WRX and WRX STI with 2.0L or 2.5L DOHC Turbo engines (EJ205, EJ207, EJ255, EJ257)
    04-11 Subaru Forester XT with DOHC Turbo engines
    05-10 Subaru Legacy GT with DOHC Turbo engines
    05-10 Subaru Outback XT with DOHC Turbo engines
    05-06 Saab 9-2X Aero with DOHC Turbo engines
    04-06 Subaru Baja with DOHC Turbo engines
    Click here for your Cam Lock Tool - $49.95
    Unique profile specifically designed for Subaru fuel quick couplers.
    Will not damage fuel line seals like universal fuel line tools.
    Will not damage fuel lines like aluminum disconnect tools.
    Molded from high strength polymer.
    One-piece construction makes fast work of fuel disconnection.
    Works on all couplers inside applicable engine bays.
    Used in place of factory tool #42099AE000 and 18371AA000
    Works with:
    05+ Subaru Impreza
    05+ Subaru Forester
    05+ Subaru Legacy and Outback
    06 Subaru Baja
    05+ Subaru Tribeca
    12+ Subaru BRZ
    05-06 Saab 9-2X
    12+ Toyota GT86
    12+ Scion FR-S
    Click Here for your Fuel Disconnect tool - $14.95
    Crankshaft rotating socket slips on over the crank snout
    Enables an engine builder to rotate a complete engine with any ½” ratchet or breaker bar
    Designed to allow easy location of TDC when replacing timing belts or other engine work
    Low profile height makes access easy
    Eliminates risk of crankshaft snout damage or backwards engine rotation
    CNC machined steel designed for a lifetime of use
    Comparable to factory tool #499987500
    WARNING: Never use an impact wrench with the crank socket to rotate the engine.
    Works with:
    93-11 Subaru Imprezas
    98-09 Subaru Foresters
    94-09 Subaru Legacys
    04-06 Subaru Baja
    91-96 Subaru SVX
    12+ Subaru BRZ
    05-06 Saab 9-2X
    12+ Toyota GT86
    12+ Scion FR-S
    Click Here for your Crankshaft Socket - $39.95
    303.402.5142
    Mar 2014
    Boulder Colorado
    Bump for lots of parts added!
    303.402.5142
    Mar 2014
    Boulder Colorado
    Bump for more parts added.
    303.402.5142
    Mar 2014
    Boulder Colorado
    Bump for addition of engine mounts!
    303.402.5142
    Mar 2014
    Boulder Colorado
    Bump for Cusco Differentials!
    303.402.5142
    Mar 2014
    Boulder Colorado
    Bump for addition of new Ring and Pinion Options!
    303.402.5142
    Mar 2014
    Boulder Colorado
    Bump for addition of Company 23 Tools!
    303.402.5142
