Ouch. You were at 16 psi and 275 hp iirc
You think 65 whp was in your reach? That's quite a jump.
There is a few things between pretty and ugly. I really don't car about carbon fiber stuff, I actually wish that FFR would supply all their CF stuff in 100% fiberglass so I could just paint it and be done with it, but anyway, it is not because it is a race car that it has to look unfinished. Adding a couple pieces of trim around the raw fiberglass cuts looks more professional and finished, that's all.
Granted I have no mirrors, front panels, windshield and a few other nick nacks, what I do have is a 2 month temporary registration!
Whoohoo!
Perhaps I'm begging for a fix-it ticket driving around but the only items ticket-able can be signed off at the CHP visit (step 2). At least my car wont get impounded if I get pulled over.
Car is getting aligned today and instead of renting ANOTHER uhaul ($800 in rentals to date) I am just driving it from the alignment shop to the muffler shop. Super sweet!!
Awesome! Any issues at the DMV? I'll be doing the same hopefully not too long from now...
set up on the dynopack there's not much left of the car! lol.
Actually yes. The first lady I spoke with told me I needed the car present at the DMV location. I insisted this wasn't correct and pulled out documentation I had printed out (Eric Hansons post on SB100) on the subject. She didn't budge so I asked to speak with her supervisor. The supervisor had a much better understanding of the process although I still found myself educating her frequently. In fact they borrowed the guidelines I had printed out and used them as a reference. Kinda scary.
At one point they asked me if i had paid taxes on the purchase. Surprisingly they didn't look at the receipts. I opted for the safe and honest route and paid $1,300 in taxes (10,990 + $3500 motor&trans) but probably could have slid by if integrity didn't prevail.
I had all my documentation filled out prior, a neatly organized folder and was as humble and kind as possible. I tried to present like I was an organized guy, i sure fooled them.
What was your baseline power before the tune?
I didn't have the exhaust routed out the 4" exit hole i cut. I didn't want to cook my panel nor have the motor ingest anything but fresh O2. I had to remove all the body panels at the Dyno and put them back on after. I have sheet screws still securing the sides & back so it only took 20 minutes.
I did leave the engine hatch on though. AKA spoiler
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
Depending on ej207 version, if it's a v7 or v8. V7 about 286-290crank hp and like 290 torque and v8 is about 290-300 crank hp and 300 torque. They are surprising more powerful than one would think due to the large head ports. With 20 psi and no mods my friend just made 325whp and 304wtorue on his Gc. With the 818 and the same tune you can get like 335whp +and 310w torque all day.
What version you have: I have a version 8 with the vf37 twinscroll. I had around 260-280 whp on a base map of only 16 max psi. Btw I am doing my body work a bit more and than tearing the engine out for its rebirth. This time it's going to get some extra metal love. CP Forged pistons, maybe 2.2 stroker build , rebuilt heads with a little more porting with a Dom 1.5. This is only if I need to. If it's just a head gasket or something stupid I will just repair and move on.
Your power is about where you should be and it's a safe tune for this engine cause most guys crank it past 20psi on em.
Congrats on dmv thing
Thanks- Chad
EDIT: I just noticed your edit, but here it is again
Went from Wilwood Caliper -->-3 to 1/8in Pipe Straight Fitting --> 18in -3 Brake Line
RAYH14572 Brake Fitting Clip (4pk) $4.95
4 x XRP981603 -3 to 1/8in Pipe Straight Fitting $13.88
2 x SBL318 18in -3 Brake Line $19.90
2 x SBL316 16in -3 Brake Line $19.90
Went for my first drive this morning. Made it from the alignment shop to the muffler shop. 2 miles during rush hour.
I don't think I will be doing that again until the car is legit, not worth the impound. It did make for a good adrenaline rush
At least the tail lights were in working order
Got some items back from the powder coater. Came out perfect
Almost done cutting and sanding the vent holes. Not my favorite part of the build
Used a 1/2 - 20 tap to extend the threads for the rear engine hatch
Off topic but got my Evolve board setup for all terrain today. 23 MPH is too fast to run it out... no bailing allowed
I'm always amazed at how much power those LiPo batteries have.
congrats on your joyride!
I stumbled a bit on the vents but ended up with following working best for me.
The sharpie was a must IMO
- bend outside piece and test fit
- mark any exposed fiberglass
- fine tune & trim fiberglass to remove any reveal
- black sharpie inside reveal edge between vents
- silicon inside vent securing with zips
- silicon outside vent securing with zips
- remove excess silicon
I dislike how the radius of the hood ring isn't concentric with the radius of the hood. Not something you did, just how its made.
Driving in half go kart mode must have been head turning in traffic. Lol
Zero Decibel Motorsports
Check out my new website!
Also, I found weights worked better than zip-ties and allen keys to secure during bonding. I used my primal-bells!
That's a good idea. I didn't even think of using my weights. That only would work for the inside vent however. It would be tough to get the outside edge of the outer vent with weights.
Craig, i noticed that as well. There is no easy way to fix that is there?
And yes...huge head turner. That's why it was sketchy...no way the popo would miss that one
Just out run them. I wanna see the chase on TV. Haha
Thanks- Chad
Brandon, you'd have to do fiberglass work or have new trim rings made.
I will leave the fiberglassing to Aloha818. Man he is going DEEP on the glass work.
I picked up my car from the muffler shop during lunch today. When i dropped it off at home I went for another joy ride around the neighborhood. This time I ran 1st and 2nd with all she had. All I can say is all you guys must have REALLY fast cars outside of your 818 because not nearly enough people are taken back by how fast this thing is. I can say with 100% confidence I have never driven a quicker car. It's intoxicating and I'm so incredibly stoked on how this car is feeling so far.
I am trying to set my brake bias. I have it set to minimize front brakes. I can't seem to get the rear tires to lock or even get a chirp out of them. I was doing a full panic stop at 45mph. If i set the bias to maximum front I CAN get the fronts to lock up however. Do i need to find a slicker surface, go faster or what is the best practice when setting the bias? I realize my tire choice isn't going to help, they're pretty soft. Any tips?
The 818 is sick fast, I am not only a builder of one but a happy owner lol
What muffler shop did you use and what setup are you running if you don't mind saying.
Yes I did re-drill the hole for better a fulcrum. I will check with Erik, he is right down the road. Thanks
When you say setup can you be more specific? I went to Mesa Muffler in Costa Mesa. He did a good job. $250 included the muffler, welding and bending, as well as fabricating 3 mounts for my AWIC and also bending/tweaking the fuel fill tube to work with the boyd gas tank.
4" exit hole
You can see one the brackets for the AWIC as well as the muffler work
One more AWIC bracket (3 total)
Fuel fill tube for Boyd tank
I also purchased 2 side view mirrors from a 944 race car. The combined weight of both mirrors was under 1lb. Impressive but frail. After drilling into my doors to install i snapped the drivers mirror adjusting it.
I think I found a similar shaped replacement so i won't have a 1/4" hole on a focal point of the car. Below are the 944 mirrors. Here are the Black Baby Turbo Mirrors i'm going to use to replace the 944 mirrors in the pics below
Hey Brandon,
awesome you went for a ride!! I think I'd be too chicken to do that, especially since the police station is a few blocks from my house!!
What are you thinking for the rear view mirror in the center. Anybody knows what is the one they are using on the blue car? It mounts on the dash.
So, How quiet is it with that big *** muffler? I do like the location of the exit pipe.
Did you follow Wilwoods procedure for bedding your pads?
Once the brake system has been tested and determined safe to operate the vehicle, follow these steps for the bedding of all new pad materials. These procedures should only be performed on a race track, or other safe location where you can safely and legally obtains speeds up to 65 MPH, while also being able to rapidly decelerate.
•Begin with a series of light decelerations to gradually build some heat in the brakes. Use an on-and-off the pedal technique by applying the brakes for 3-5 seconds, and then allow them to fully release for a period roughly twice as long as the deceleration cycle. If you use a 5 count during the deceleration interval, use a 10 count during the release to allow the heat to sink into the pads & rotors.
•After several cycles of light stops to begin warming the brakes, proceed with a series of medium to firm deceleration stops to continue raising the temperature level in the brakes.
•Finish the bedding cycle with a series of 8-10 hard decelerations from 55-65 MPH down to 25 MPH while allowing a proportionate release and heat-sinking interval between each stop. The pads should now be providing positive and consistent response.
•If any amount of brake fade is observed during the bed-in cycle, immediately begin the cool down cycle.
•Drive at a moderate cruising speed, with the least amount of brake contact possible, until most of the heat has dissipated from the brakes. Avoid sitting stopped with the brake pedal depressed to hold the car in place during this time. Park the vehicle and allow the brakes to cool to ambient air temperature.
Also, you've got big brakes... you're going to need to get some serious heat in them before they are going to grab hard enough to rip your face off.
Bed the pads, then take it to a place where you can drive hard enough to get some heat built up.
When you said you went to a muffler shop I thought you might of changed your setup since the HB show. For 250 that's crazy good.
I stumbled upon a nearly identical dash mounted mirror as the FFR Blue R car. I'm struggling to find it now and wish I had just purchased while I was on the page. If you find one like it please share the link, I will do the same.
The car isn't as quiet as you would think. It's pleasant at idle, but still plenty loud when you get on it. I have been meaning to get some cockpit video and a flyby. Perhaps after work.
Good stuff. I haven't bedded my pads, in fact I didn't know there was a procedure for it. Will do
Thanks brotha
What pads are you running? Bedding pads isn't such a big deal for street pads, 50 miles of normal street driving will do it fine (don't get on them hard until then). Race pads are another story. You need to bed these or they will not perform up to their potential.
The same goes for heat. For a street pad, they are designed to operate at their full potential from ambient to 500-600 deg. F (maybe more for something like a Hawk HP+). Race pads however don't get into their optimum range until 200 deg or more, but they'll perform happily up to 1,000 - 1,600+ deg F depending on the pads you get.
Keep in mind, we're talking about "optimum" performance. All pads will stop the car at ambient, just not as well as they might be able to should their optimal range be higher. Note, even at sub-optimal levels, a good race pad will stop the car better than an everyday street pad. I used to run my Carbotech XP10s & XP12s on the street for short durations and was always nervous that the cars around me couldn't stop as fast as those things would bring my car down from speed. I've heard that Hawk's line of race pads are not nearly as capable at ambient compared to higher temp ranges.
The real concerns with running more aggressive pads on the street is that they do unhappy things, like make hellish noise, and leave lots of dust (some of which is highly corrosive depending on the pad compound). Also, often (because they're not in their optimal temp range) they start wearing away the transfer layer that should previously have been deposited via proper bedding...then they start re-depositing it in uneven ways, leading to pulsing and generally poor braking performance (no, they don't "warp" the rotor, they're just leaving uneven deposits, which makes the unsuspecting tech-goon at your local parts store claim he's measuring "warping"). If you get on the brakes hard after this has happened, its not a pretty sight (mmm...yup, ask me how I know). Different pad compounds are apt to do this to different degrees, so there are no real absolutes here (it is friction after all, and that's always compound/condition specific).
Moral of the Story: Don't run your super-kill, ultra-awesome, race-only pads on the street.
Best,
-j
I ran DTC-60's on the street before. The low end operating temp was the same as the Hawk HP+, but they stopped much better. They were stupid loud, and stupid dusty. People half a city block away would turn and look to see what sort of wreckage was going to occur when they heard the squeal.
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
I have Baer brakes on my Mustang, the fronts are 13 inch rotors and the rear are 10 inch. I change the high performance pads for stock because of their poor street performance. I have tracked the car several times and have had no terrible wear or fade. The car weighs about 2800lbs. I think with the 818s weight you should not have to run a rotor killing pad to stop. Another side effect with race only pads is the metal particles get embedded in your wheels, kinda uglies them up.
See, I've heard conflicting stories on Hawk's line of race pads. I tend to believe the folks with your experience (some local folks have done/reported the same as you). But there's always "that guy" on the web decrying them as horrible safety hazards on the street. They're all like, "You can't do that, you'll die!" Meh.
What they really are is damn embarrassing. In the paddock everybody knows what's up, but on the street you get looked at like you're stuff is all jacked up.
-j
Stop Tech pads worked great for my autocross. 80-20, smoked the tires and was even and very nice. My brakes stopped on a dime and did not fade at all, they outlasted my motor lol. Stock brakes are all you need on this car. Anything more and you might have too much braking clamp.
Wrong post, my bad.
