Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
Thread: #93
    Freeport, ME
    Congrats, major milestone completed!
    Dan
    Mechie3's Avatar
    Indianapolis
    Excellent!
    Zero Decibel Motorsports
    Check out my new website!
    Michigan
    Congrats! Let me know if you ever need another set of hands!
    Canton, MI
    Thanks guys!
    Canton, MI
    First test drive yesterday. I will post a video later today.
    Canton, MI
    Got one seat installed. It fits good so going to order another. Wasn't to hard to make mounts and it gives more room.080CCF5B-0984-40CC-8D05-59A1272E7094_zps4qvvuvig.jpg
    QC, Canada
    I don't know if your floor is on, but let's assume it is, would you need it to be off in order to make the seat installation easier or floor on or off won't make a diff?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Canton, MI
    It wouldn't make much of a difference. I used 3/8-2" flat steel and bolted the seats to that then that to the frame with enough off set so the bolts they supply work. You can get a wrench on them pretty easy. For the back there is room to fit a socket down and do it that way. For the harness I drilled and tapped the 3/8 steel and bolted the side and sub belts to it with the hardware the provided. Now I'm sure this is not what most people would do, they would what it strait to the frame but this way I can take it out all in one unit. If the seat did break off the flat steel would still be bolted to the frame. I don't plan on doing and real racing, but the seats look better with harnesses and the car is safer overall with no top. I can post some pictures of how I did the mounts if you want.
    Feb 2014
    Ramona, CA
    Quote Originally Posted by Blitzkrieg View Post
    Yes, put some pictures up. I have the same seats. Did you get the adjustable rails too?
    Canton, MI
    Quote Originally Posted by matteo92065 View Post
    No I didn't. I don't think there is any room to slide anyways, inless you got the cross bar out.
    Canton, MI
    Once I figured it out it they weren't to hard to make if you have the tools. And the way the bolts on the seats sit you have to angle the brackets a little bit.
    Canton, MI
    Here are some more FB936F05-4F9A-4744-A9E4-951FEA99175C_zpsgvc7isoa.jpgA5A8A045-AFA2-4995-AEC8-C5E6D0F7E040_zpsnfokubzj.jpg the back one has to be longer for the mounting point and it has to have that little angle on it for the welds but its made up for where the seat mounts the the bar.
    B3509BC8-6A11-4718-BAB1-214CAC1401D1_zpswbodxh1s.jpg painted with truck bed liner.
    Canton, MI
    Smile
    New tank in the car, fits perfectly and does its job.
    FAF11429-F676-42D7-A8E8-C44FC9BF713D_zpsp15l59hd.jpg59E01F89-E386-4860-8C8A-E1DC0D24AC6E_zpsbkzgpcgd.jpg2E777671-BC00-462E-B33E-04B2204793D1_zps9igkvadr.jpg
    Thats my wookie brother there he is 6'5". I'll try to get my friend over who is 6'7-8" to try and fit in it.
    QC, Canada
    Wow, super slim tank, nice job! Might lose 3-4 gals?
    6'8", that is a lot!!! lolll More than a foot over me.
    Canton, MI
    It's at about 6 gallons I think.
