My goodness it's been a while since posting about #71. Lets see if I can get everyone up to date.
Finished the passenger side window frame molds.
Glassed the bolt plates onto the front of the doors and started the bodywork.
Worked down all the body seams.
Mounted the rear diffuser so the alignment on engine cover could start. Mounted the engine lid, hinges, struts, latch and handle.
Worked on perfecting the hatch to body seams.
Work on getting the rear glass to body fit right. But I'm waiting on a roof scoop to install first.
Finished aligning the front end and worked on the side seam.
Glassed in and rough body worked the headlights.
Mounted the hood release handle and latches and struts.
