OK it's not another thread to talk about which is better just to get your attention!
I've decided to migrate back to the rear of the car for some upgrades that I've been thinking about since day one of the build. At the time just getting it on the road was the priority so now I've had time and money to change the 4 link out for something a little more adjustable. That's the operative word: adjustability. I've decided on a Watt's link after spending some time with James Watt's patent application on his improvements to the steam engine. I'm not sure when it was first applied to suspensions but I'm glad it was. I plan on a style of Watt's link that is mounted on the chassis instead of the pumpkin kind of like the Fays2 that Mustangs use. I have a good reason for that. There are pros and cons for any suspension system depending on what you need it for so I have done my best to design it for street/ auto cross.
I plan on using the quad shock brackets as the main support for the cross member with some added support to tie it to the 2x2 rail above so it will not be fully loaded on the welded bracket. The member will be a simple rectangle with triangulated arms to handle the lateral loads of the chassis. The bell crank or propeller is going to be made of 6061 aluminum with vertical mounting plate that will have several adjustment points for raising and lowering the roll center in the rear. I like that the roll center is exactly where the pivot point of the propeller is so there is no calculation involved. The lateral links and diff mounts are probably coming from Speedway since they have the best variety of pan hard bar brackets I've seen so far.
I like the idea of having the roll center mounted rigid to the chassis so I can adjust it up/down with ride height as well as the cross member adjustment. So the next step is to put the roadster back on the lift for mockup and tacking the pieces then remove and weld it up. This is supposed to be a completely bolt in project so I can remove it if I wish and return to the present system without any modification. Also, I will be driving the car so there will be no downtime as with the front suspension project I did. At some point I will be adding a third link in the center of the diff but the Watt's link will be first. I will in effect be running a 6 link suspension. Then as I've discussed before, I can remove one UCA and do a little experiment to see how the "poor man's 3 link" works. The final goal is to fab a 3rd link that will use the mounting points of the 4 link UCAs (diff and chassis) but in the centerline of the chassis. There may be a few days of downtime when that happens but first things first.
I had to show my pic of the metal I got at industrial metal supply. You can get some great deals from remnants or you can go custom and pay more. I got these for $48 dollar. If I had had the aluminum cut to size it would have been $30 just for one piece. I love a good deal. The shiny aluminum plate is for a dead pedal.
Any thoughts or other input is always appreciated and usually educational.
WEK.![]()
