Page 2 of 2 FirstFirst 12
Results 41 to 43 of 43
Thread: Upgrade - LCA SN95 Spindles 99 PBR Brakes & New Shocks
    Senior Member HookedonFord's Avatar
    Panhandle, FL
    Koni Shock (30-1720) and Koni Shock (30-1721) Dyno
    Panhandle, FL
    I finished up the front end. Only items left are brake bleeding, adjusting ride height, and then alignment.
    Panhandle, FL
    Post Follow Up
    Following up after bleeding the brakes, adjusting ride, and getting the alignment.
    Since I had purchased front and rear Koni shocks, I went ahead and flipped the rear brake caliper mounting orientation to a front mounted orientation and I installed the rear Koni shocks as well. A month before I started this front upgrade I had already installed the Hawk HP plus+ rear pads on 1999 GT rear calipers and was waiting to bed them in with the new 1999 PBR calipers with HP plus+ front pad per Hawk guidance located here - http://www.hawkperformance.com/perfo...t/pads/hp-plus in the General Questions section.
    Everything went pretty smoothly with the final brake bleeding, shock ride height adjustment, and alignment. I am still communicating with Mr. Neuman at http://www.vi-king.com/ and looking forward to trying out front and rear DA shocks they are working on/planning to offer.
    At this point, I really like the way the car handles and the braking abilities over the previous equipment. I am impressed with how much it improved the braking, so thanks Wayne Presley, for that HP plus+ brake pad advice during a dyno visit.
