So earlier guys were talking about the risk of heat soak on an AWIC setup on long road courses. Doing an oversized radiator, oversized Heat Exchanger and high-flow water pump will help but what about borrowing the fuel cooler idea for the AWIC setup? Instead of running ice through the water tank, what about running a small evaporator core through the box? Then instead of dumping ice in it which eventually melts, you can toggle on the AC when the water temps start to rise.
It's all aluminium, could be fabbed up pretty easy...
This idea has crossed my mind as well, but it will have to be in time and over some testing.
