Results 1 to 40 of 48
Thread: Chassis #111 2006 STi with Blouch 2.5XTR First Drive Video
    Puyallup, WA
    Chassis #111 2006 STi with Blouch 2.5XTR First Drive Video * 10/7 update
    10/7 update:
    My tuner sent me a base map for Blouch turbo and supporting mods. This car is INSANE. Just wow. Heres a short video
    https://vid.me/H5n
    Reached a huge step in my build with a maiden drive out of my driveway. 2006 STI donor with 6speed as well as a Blouch 2.5XTR Turbo and supporting mods. Will be installing a muffler as just a downpipe with high flow cat is too loud.
    Car has not been tuned yet so was not able to do anything fun. Shifter with reverse lockout was completed after the drive. (Even tho i was digging the tube extension shifter )
    Take a look at the video: https://vid.me/xZ3 https://vid.me/Nvv
    Edmonton, Alberta
    Congrats, big step!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Senior Member jayguy's Avatar
    Las Vegas
    Awesome, should be a blast around there when you're done.
    Great job Kurk,
    Please share some details on the 6 speed transmission mod.
    What size tires and whees?
    looks great.
    Leesburg, VA
    Congrats and the car sounds great! What were your impressions? Anything you have to adjust? Looked pretty solid, no odd noises.
    Puyallup, WA
    The engine sounds great. Purrs like a kitten at low rpm. Anything over 3k gets weird. It's still running in the stock sti map. Will get a base map from the tuner once he opens tomorrow and a dyno tune scheduled for the 25th.
    Tires are 255/35/18 in front and 295/30/18 in rear.
    Frame cross members required modification under the 6speed to fit. Other than that, with the sti hubs and running gear, it wasnt a problem. Sti axles were used for the rear.
    Puyallup, WA
    The shifter worked great with the 6speed. A little tight but ill get used to it.
    Didnt have any cels with the exception of TGV related stuff and the fuel tank. So overall really happy with everything. Cant wait for a tune and seeing what kind if rubber can be burned.
    The front end felt like it was too light and had the sensation that it left the ground on some of the bumps during the ride.
    Leesburg, VA
    Interesting, hopefully putting the body on will settle that down. Have you done an alignment? And do the front wheels rub? I'm guessing you'll be doing some fender flares out back?
    Puyallup, WA
    Ive done an alignment but will redo it once all of the suspension components adjust into place.
    The body doesnt add much weight tho. Im hoping youre correct tho.
    I have no rubbing issues as of now. Yes, body flares will be required and installed
    Nice job! Does not sound too loud to me.
    Puyallup, WA
    I can hear it a half mile away over a hill
    Exeter R.I
    That's what you want, it supposed to be loud!!! Plus cars can hear you better to avoid you.
    Puyallup, WA
    Im with you. It sounds awesome within the car. My only concern is passing inspection to get it street legal.
    Thoughts?
    Puyallup, WA
    Update with new video
    did you put your 500lb springs in the back?
    Leesburg, VA
    Is that a breaker bar on your shifter?
    Puyallup, WA
    I installed the springs as recommended by FFR for the S.
    Puyallup, WA
    LOL, i wanted to make sure the shifter functioned properly before i welded in the setup with the reverse lockout. My only issue with the shifter is that there is no "home" position. Ill have to figure something out with some springs or something. Makes for finding gears difficult sometime, especially on deceleration.
    Leesburg, VA
    My wrx 5 speed had a slot with a spring inside to keep the shift selector in a "home" position, that was located in the back end of the transfer case housing. Do STI transmissions not have a similar feature? The thing I'm talking about keeps the selector between 3rd and 4th in neutral.
    Puyallup, WA
    It may be just slop within the shifter linkage. Ill take a closer look and tighten things a bit more
    San Diego Ca 92106
    [QUO
    TE=Kurk818;172929]LOL, i wanted to make sure the shifter functioned properly before i welded in the setup with the reverse lockout. My only issue with the shifter is that there is no "home" position. Ill have to figure something out with some springs or something. Makes for finding gears difficult sometime, especially on deceleration.[/QUOTE]
    Would a gate for the shifter work?
    Puyallup, WA
    Dyno tuned today. Put down 378hp and 381tq at 21.4psi on 91 octane.
    This ride is insane. Love it!
    https://vid.me/oCi
    https://vid.me/oCi
    WOW Kurk, I thought my car would be crazy fast 195hp/222trq@12psi. You are double that. HOF.
    I like your inter cooler mounting.
    Puyallup, WA
    The feeling that one gets after putting in all the hours with the STI donor and wiring and seeing it put down that much power can be compared to child birth, its a beautiful sight
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    Very awesome Kurk!
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
    Virginia
    Intercooler placement
    kurk, I am very interested in how you placed your intercooler. Could you take some more descriptive photos and post them for review. Thanks Grayghost ROGER
    59 Fiat 1200 roadster
    1963 alfa 1600 gulia
    1949 MG TC
    3 volvo turbo stick wagons
    restored 1968 firebird 400 convertible
    FFR 818 Chassis #172 pickup 04/16/2014
    Puyallup, WA
    The intercooler is a front mount and all of the associated plumbing. Additional silicone tubing was purchased to connect everything. The current mount is just temporary due to the requirement of needing final body fitment. Its nothing special. Just gets the job done.
    Just took it for a spin, wheel spin in 4th doing 60mph
    Quote Originally Posted by grayghost View Post
    Sgt.Gator's Avatar
    Bend, Oregon
    I'm looking forward to seeing how well your RMIC works with the body installed and real road/track driving. Subscribed!
    Owner: Colonel Red Racing
    818R ICSCC SPM
    south-central CT
    I, like others, plan on using a six-speed. I have mine and a LSD for it and the one adapter piece that FFR sells. I will do a gear change to make it close-ratio.
    Info on how to actually do it seems impossible to find.
    Could you post info? Hopefully in the 818 thread about it.
    Looks like you are using the standard FFR shifter? I bought a shifter from a MR2 to use in mine. I hope to feel the neutral without added springs or mechanisms.
    Reverse lockout is not a big concern to me, but I'd love to see pictures and explanation of how the transaxle was modified.
    Puyallup, WA
    Im considering going with the k-tuned shifter or other alternative that is not plastic. I have difficulty finding gears.
    With the MR2 Shifter, ill need reverse running cables correct?
    south-central CT
    No, Just the reverse lockout cable. Mind you, I am not building yet; just accumulating parts like a squirrel collecting nuts for the winter.
    On the internet, I have seem installations in non-818 kits where they used the MR2 shifter. You can go straight back with the cables by mounting them to the upper side of the pivot.
    Puyallup, WA
    So I will need new cables to run an MR2 shifter? Im thinking of ordering the K-Tuned shifter that FFR offers.
    Hi Kurk,
    I am running the MR2 shifter. The cables come out the back (toward the engine). They connect to the trans with the standard FFR configuration. In the picture below you can see a big loop as the FFR cables are about 8ft to long for this configuration. cable.png I am going to get shorter cables.
    Since there is some clearance between the inner and outer cable jacket. Any bend in the cable will add backlash. So with the extra loop I get almost 3/16" movement at the shifter cable connection before any movement at the trans cable connection. It is important for everyone to try and run the cable with the least number of bends.
    The MR2 shifter is a very short shifter as you can see in my dyno video. I need a better video of the Shifter. I like it.
    Puyallup, WA
    I noted that in your video when you originally posted it. Ill definitely have to consider it.
    https://vid.me/oCi
    Hi Kurk, awsome power! But should the results be higher if they front rollers were disconnected?
    Puyallup, WA
    Quote Originally Posted by DMC7492 View Post
    You bring up a very good point. Im not sure.
    Any professionals want to chime in? Its a mustang dyno
    Where's the dyno plot?
    Tony
    Puyallup, WA
    Here's one of many
    http://imgur.com/Hqxupxb
    Quote Originally Posted by Turn In Concepts View Post
    Tony
    Looks about right to me, but without units on the boost plot and knowing what fuel is being used it's tough to say.
    We had one on our dyno last week and really didn't see a huge increase in power over an AWD application. It was maybe 5% higher if i remember correctly.
    Tony
    Research Calibrator sponaugle's Avatar
    Portland, OR
    Congrats on getting it up and running!
    I assume that the extra length on the STI front axles didn't cause any problems? I am just about to drop my transmission in and I'll be using those same axles with the stubs changed over.
