Results 1 to 18 of 18
Thread: Aeromotive pump and the fuel controller
    Senior Member Quiny's Avatar
    Massachusetts
    I like many others have opted to go with the Boyd tank, that being said I think some of us (like me) retained the fuel pump controller. I have go-karted and haven't seen any issues but has anyone else seen any problems? My concern is that the Aeromotive pump may not like reduced voltage.
    Suisun City, CA
    From my knowledge of the system, the fuel pump controller regulates the ground to create the appropriate 33%, 66% or 100% duty cycle of the fuel pump. I've been beating the crap out of mine with the OEM fuel controller and the Boyd tank / Aeromotive pump. Zero issues to date and I've put a few track weekends on it, too.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
    How much boost are you running? That's what will make the pump work really hard.
    Quiny, I was also concerned about this,look at this controller from Aeromotive Fuel Systems.looks like they are a step ahead of us.
    Here's the link http://aeromotiveinc.com/products-pa...ed-controller/
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    T hx for posting the link. They say on that page that reducing voltage is terrible for pump motors but if thats true, I wonder why the factory does it and doesnt have tons of fuel pump failures in all their vehicles?
    Massachusetts
    Very interesting, looks like they are controlling motor speed with frequency instead of voltage, something like an AC drive except using a square wave. Their statement does have some merit, lower voltage = higher current as long as power stays the same. Higher current tends to burn the commutator and brushes which in turn cause high resistance that could stall the motor at lower voltage. Do we know for sure that the stock controller doesn't work the same way? I just assumed reduced voltage, I may need to blow the dust off my scope.
    ROMraider calls it "Fuel Pump Duty Cycle". If it's named correctly, then the OEM setup does not vary voltage - it does the same thing the Aeromotive unit linked does.
    Suisun City, CA
    Quote Originally Posted by Jaime View Post
    I'm running around 18 psi at peak boost.
    Finished: NEVER!
    Exeter R.I
    Yeah the oem controller is the same thing.
    Senior Member xxguitarist's Avatar
    If it's considered duty cycle, it's likely a PWM for the supply voltage. It's not "reduced" except if you average over a time. It's just switched, quickly (square wave), so that the pump is on for say, 33% of the time, and you get 1/3 of the fuel (aprox) vs connecting the pump to the battery.
    Dimming LEDs works the same. You won't get light out of them at half the voltage/current, so you switch them on & off quickly. Your eye averages it out. The fuel flow in the tubes does the same thing.
    Massachusetts
    Does anyone have a picture of the fuel pump controller for 02 WRX. I have my controller somewhere but have to go looking. The service manual I have is no help.
    Quote Originally Posted by CU9DZ View Post
    Here is an ebay picture of an 02wrx fuel pump controller
    Massachusetts
    Yes I found mine. Thanks. Now I just have to untangle the mess when it gets warmer.
    Nepa
    Is the fuel controller really needed if you have an adjustable fuel pressure regulator.and Walbro pump ?
    Leesburg, VA
    I know some have hard wired their fuel pump directly to 12V and it works but it will wear out your pump faster running it at full power all the time.
    Nepa
    I guess I better get one to be safe. Are all years 02-07 the same?? I basically have a 07 setup. But may have a 02 controller laying around
    Leesburg, VA
    Quote Originally Posted by Samiam1017 View Post
    I can't see why an 02 controller wouldn't work, especially if you're using a Walbro or other aftermarket pump.
    Nepa
    thx found an 02 unit
