Thanks Thanks:  4
Likes Likes:  8
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 297
Thread: The 'Savage' build thread
  1. #121
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    I love the ipad. Are you going to have it set up with any data logging apps? Or what is your plan for it?
  2. #122
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    It will be used for Audio, Navigation (Navigon), and OBD II monitoring/logging/etc (Dash Command) plus anything else I might want to use it for. It will connect to an iStreamer D/A which will in turn be connected to an amp. I will probably put a AudioControl Overdrive + between the iStreamer and Amp. I am using a PLXDevices Kiwi for the OBD II connection.
    The iPad mount is from Fifield Fabrications.
    I did the final sanding last night. It just needs a final coat of primer then it will sit until we are ready for paint. The dash will be painted orange to match the other trim on the car. Unfortunately I dropped my orbital sander on my right middle toe and broke the toe. Will be off my feet for a couple of days.
    Power tools and bare feet not smart.
    Larry
  3. #123
    Encinitas, CA
    Quote Originally Posted by K3LAG View Post
    Bummer, Larry! Hope you heal quick.
    When not at work, I pretty much live in shorts and OluKai sandals. I try to change to jeans and closed toed shoes when doing auto work, but not always. This will be a reminder to me.
  4. #124
    Member Westview's Avatar
    Jan 2013
    Columbia, Maryland
    Larry
    Och!! Hope if heals quick! The dash looks awesome, can't wait to see it person.
  5. #125
    Mechie3's Avatar
    I've done metal working at home in sandals. Usually end up with hot chips on my toes and then I say to myself "well, that was dumb" and I go inside and put on shoes. (sometimes...).
    Zero Decibel Motorsports
  6. #126
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Here it is, ready for paint. Also a couple of pictures showing the Dash Command and Navigon screens.
    Will see the podiatrist about the toe on Monday. It's feeling better already, but being careful not to do anything to make it worse.
    Larry
  7. #127
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Major milestone reached!
    This evening we reached a major milestone. I buttoned up the final grounds and plugged in all the connectors on the harness and methodically started applying power and testing. It's alive and everything seems to work as expected. I was able to communicate with the ECU and married my AccessPort.
    I'll still have to complete the light wiring once the body is on, but I have connectors installed for both front and rear light harnesses so that will be easy.
    Here is the final pile of discarded wire and connectors:
    All we need to do to start the engine at this point is finish the cooling system and add all the fluids. Should be running soon.
    We still have to complete e-brake, shifter, seats, install rori's column mount to shorten the column, torque suspension bolts and do rough alignment before we can go-kart. Maybe we'll go-kart Labor Day weekend but probably a little later than that.
    Now that I've finished the harness, I'll complete part 4 of my diet process, which is earlier in this thread, in the next few days.
    Larry
  8. #128
    Richmond, VA
    Nicely done. I like where you're going with this. I am going down a similar road, but looking at an ipad mini in the center console. I'm looking at Out of Sight Audios Mark 3 bluetooth receiver
    http://www.outofsightaudio.com/mark-3.html
    It's only 14 oz. I'm not much past that, but starting to think about the small self powered bazooka tubes, and running 2 speakers off that internal amp. If I can get it up under the dash and do a quick disconnect, then I'm only left with 14oz and 2 speakers on track days. I can live with that.
    I am also looking at dash command and using it to monitor air intake temps after the AWIC with the addition of an additional sensor. You definitely have a better setup as far as being able too see the interface. Again, I like the direction you are going, can't wait to see the finished product.
    Travis
  9. #129
    Encinitas, CA
    Good job, Larry! I haven't decided if/what I'll do for a sub; I'm also thinking a small, removable bazooka tube like Travis. However, for main speaker power, I already bought an Alpine KTP-445U Class D amp. In bridged mode, it's a solid 90W to 2 channels at 4 Ohms from a 1.5 x 2.5 x 8" package! Thought I'd throw it out here for anyone that wants a decent amp is a very small/light package. Being a digital switching amp, it doesn't throw off a lot of heat, so you can tuck it away without worry. Perfect for a weight conscious 818 audio system. I'll be running a single DIN headunit and have a smartphone cradle.
  10. #130
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    8/30 Update
    Nothing particularly exciting or technical this week, just an update.
    We have 8 things on our list to get accomplished this long weekend:
    Install Group N motor mounts
    Install Group N transmission mount
    Install upper radiator mounts from Mechie3
    Install steering column spacer from Rori
    Complete cooling lines
    Modify rear firewall and install
    Install Lokar E-Brake Handle
    and install anti-corrosion felt things on the battery posts (gotta include the easy stuff, makes it easy to cross things off)
    As of quitting time last night we have 5.5 of them done.
    Motor and Trans mounts installed:
    I'm very glad I decided to put these on. They are substantially stiffer than the original old mounts from the donor. It would have been a lot easier to put them on before installing the engine, but I just decided recently to do it. Even at that, it only took a bit over an hour to do all three. Things are much more solid now.
    Upper Radiator Mounts installed:
    Steering column spacer installed and column shortened:
    This is a big improvement for us comfort wise. With the hub and quick release installed the steering wheel was really too close. It should also look a lot better. Here is a picture before Rori's spacer as a comparison.
    The firewall is only half done. It is cut and riveted back together, but not yet installed. That will get finished on Monday
    The picture of the firewall looks pretty bad with all the hand/finger prints on it. I'll clean it up for the installed picture.
    No picture of the felt things on the battery terminals, nothing too exciting there. I do find they work well on every car I've used them on.
    We should have no problem finishing our remaining 2.5 items on Monday. Fingers crossed .
    We are really close to firing this thing up for the first time.
    Larry
  11. #131
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    For anyone wondering, we didn't finish the planned list this weekend. All got done except the cooling lines. Had a couple things pop up that took time away from garage. I'll post some pics of the finished firewall and e-brake sometime soon.
    Larry
  12. #132
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    First Start
    A few minor issues to resolve, but it's alive!
    https://www.icloud.com/photostream/#...B-163EA633FDB6
    Larry
  13. #133
    Apr 2014
    Shelton, CT
    Congrats on the 1st start!
  14. #134
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Love all of the orange, congrats on first start
  15. #135
    Way to go Larry, I hope to be doing the same in a few day. I started wiring today.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Last night was a productive night. The goal was to get the leaks fixed and tidy up a bunch of things. My Dad, step mom, and mother in law are all coming to visit next week so we wanted it to start, not leak and look decent for them.
    First the leaks. We had 3, one of each fluid. The transmission was leaking from the passenger side axle seal. Got the seal for $8 from the dealer, dropped the passenger side suspension, popped the old seal out and new in, then put it all back together. Took about an hour. The oil leak we first though was drivers side valve cover, once we eliminated that we thought it was coming from the front seal on one of the cams. Turned out to be much simpler than that, the bolt/plug next to the drivers side upper cam was very loose. Cleaned it up, put a dab of sealant on it and reinstalled, problem solved. The final leak was from some of the joints in the cooling system. We got all of those stopped but one which is still dripping a tiny bit.
    Once all those mechanical things were done, we moved to cleaning up the center tunnel. Attached all the cables and tires and cut a slot in it for the handbrake. Once that was done, we put the tunnel aluminum in and reattached the rear firewall and cleaned things up. I think it's ready for people to see it now.
    Maybe we'll bolt the wheels on for good measure.
    Larry
  17. #137
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    One of the minor issues I had once we started the car was a very high idle and trouble code from the IACV. Each time we started the car the idle actually got higher. I found directions on NASIOC for cleaning the IACV and followed them. My IACV was so crudded up the valve wouldn't move at all. After a thorough cleaning I reinstalled it and all works as expected now.
    If you have any problems with the car idling properly, check your IACV. Be sure to get a new gasket, because apparently used ones don't fit or seal correctly.
    Here is the NASIOC thread with the cleaning info: http://forums.nasioc.com/forums/show....php?t=1704762
    We also worked on the throttle mounting a bit. Like some others I didn't quite have full throw of the throttle. We modified the FFR provided bracket to move the top of the pedal mount closer to the firewall to give us a bit more throw. We also took some of the flex out of it while we were at it.
    We continue to work on minor stuff to prepare for go-karting while I finish my welding class. In a couple of weeks I'll make seat brackets and we will get the seats and seat belts in. I hope to go-kart before Halloween.
    Larry
  18. #138
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Nice diagnosis and fix on the IACV.
  19. #139
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    It's been a few weeks, so here's the latest...
    We had been feeling like we hadn't gotten a lot done in the last few weeks, but last night we finally feel like we are making real progress again.
    Seat belt mounting is pretty much done and floor is temporarily installed. Seat brackets should get finished up in the next week. After that I think we will be ready to get it down off the dolly to prep it for go-karting!
    We also temporarily installed the dash so we could get the wire routing finalized.
    Larry
  20. #140
    Senior Member metros's Avatar
    NoVA
    I can relate to the ups and downs of feeling like you're progressing toward a final product. Looks like it's really coming along though. Keep plugging away and you'll be fitting the body in no time.
  21. #141
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Floor, Seats and Seat Belts installed
    Last night was very productive. The floor, seats and seat belts are all installed now. Oh, and a nice orange shift knob.
    I'll post a more detailed post on the seat install next, but here's some pictures of everything in place and a few grins to boot.
    Should only be one or two building sessions away from go-karting now.
    Larry
  22. #142
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Seat Install
    Here are the details of my seat install.
    Sparco Chrono Road Medium size with Sparco sliders
    Boyd Tank and firewall moved back accordingly
    Goal: Mount the seats as low as possible in the back and a few inches higher in the front for a comfortable slightly bent leg position. Since Dave and I are several inches different in inseam we need the seats to slide a couple of inches.
    The rear of the fixed rail of the slider are bolted directly to the side-to-side bar of the frame. Since the front of the seats are elevated, I made shims to go between the frame and sliders and between the slider and nut so the nut and slider would be fully supported even thought the slider is mounted at an angle.
    With our planned rise of about 2 inches, the front the shims needed to be made at an 8 degree angle. Here are the shims:
    The wider ones go between the slider and frame and the narrower ones go between slider and nut.
    I made brackets to support the front of the sliders about 2 inches above the frame. The brackets are made from 1" thick walled tubing. The thicker wall probably isn't really needed, but since the ends are unsupported I opted for the extra strength. The top plates that the slider bolts to are 3/16" thick x 1" bar. The top plates are also angled at 8 degrees. Here are the brackets that support the front of the seats:
    Here is two views of the brackets and sliders installed:
    In the top view you can see how the back of the sliders is attached to the frame with the shims and how the front is bolted to the frame. The view from the foot well shows you how they are inclined in the front and how it fits with respect to the frame.
    After these were taken I shortened the slider handles to provide a bit more clearance with the diagonal bar.
    I hope this helps someone else trying to figure out how to mount their seats if they are in a similar situation.
    Larry
  23. #143
    Better welds than my mech, hey? lolll
    Nice seat belt color! Did you ever mention where you got them?
  24. #144
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I've always wanted to learn how to weld so I used this as an excuse to take a welding class from the local community college. It was a bit expensive but well worth it. About 36 hours of training over 6 weeks. Those are my first welds other than the practice plates we used in class and some practice I did with some of the scraps from the bracket parts.
    If you have the option of taking a class like that, I recommend it. It's certain possibly to learn on your own and practice, but the engineer in me like to know the right way to do it. The hour long lecture on welding symbols probably won't be all that useful for me, but it's interesting nonetheless.
    The seat belts are from seatbeltsplus.com, the same place aloha818 got his.
    Larry
  25. #145
    Larry, which model you got? 3-point non-retracable with 6in buckle?
    Thing is I can't find one that has a black latch like your. They are chrome.
  26. #146
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I got the 3-point retractable with contoured sleeve. However, the sleeves kind of got in the way so I pulled the short section of belt and buckle out of the sleeves. If I were to order them again I would probably get the ones with the 12" cable on the buckle side.
    Larry
  27. #147
    Ok I see. Surprisingly, they don't seem to retract on your picture, they are loose on the seats and firewall.
    I'll check how long I need for a cable buckle and I'll order a set, I like the fact I can get them in electric blue to match my car, just what you did.
    Did you have to order the 5 bucks installation hardware?
  28. #148
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    The retractor springs aren't real strong so the friction of them draping around the seat and the fact that they are buckled makes them look that way. When they have a body in them, the belts are pulled out further and the retractor pulls a little harder.
    I ordered the hardware and used much of it. I used the L brackets to mount them to the frame and all the nuts and washers. I wanted some of the bolts to be different lengths so I bought a few. I think I had to buy a couple extra washers and nuts too. 7/16 bolts aren't cheap so $5/set isn't bad.
    Larry
  29. #149
    Good to know. So with a body under, their retractable feature felt pretty much the same as OEM belts? I guess yes as they are certified for road use, according to them.
  30. #150
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Go Karted today!
    Well, technically it was yesterday. What great fun. I haven't driven a stick shift in about 22 years, so my shifts were a little sloppy. The sound in the video revealed a rattle that neither Dave or I heard while driving. I had temporarily wire tied some things to the frame in a few spots to keep things from floppy around and I think something was hitting the frame. Probably a connector.
    Here's the video: https://www.icloud.com/photostream/#...7-39C90877C230
    Larry
  31. #151
    Great Job Larry,
    What's your plan for the tablet screen?
  32. #152
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Stereo, Navigation and in theory Obd2 based display using dash command. Dash Command is causing me some trouble though. About half the time it gets OBD2 protocol errors. I have heard both that it's a Subaru issue or that it's an issue with Cobb tuned Subarus. Still looking into it.
    Larry
  33. #153
    Senior Member AZPete's Avatar
    Congrats, Larry, on the smooth go-kart trip . . . no smoke, flames, dropped parts nor tow strap! I'm planning on a tablet also so I'll be watching your OBD2 solution.
  34. #154
    Encinitas, CA
    Hi Larry,
    I just starting to tackle my wiring harness, and have found your tutorial invaluable. Do you plan to finish Part 4? I think the 4 part series would be useful enough that you should copy it over to a new thread in the Electrical section and have a moderator sticky it up top, so everyone will benefit from the effort you went to to document it.
    Lee
  35. #155
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Hi Larry,
    Lee
    I should do that one day. I've just been busy with other things. Maybe I'll try to do it over the long Thanksgiving weekend.
    Larry
  36. #156
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Nothing major to report.
    AWIC installed and system filled an bled.
    New wheel studs and spacers installed.
    And we have started to install the body.
    Here are a couple of progress pics:
    Larry
  37. #157
    You'll want to cut the flat excess off the front of the side body panel (sail). When the manual say to place it 5/8" back from the front of the frame tube, they mean after trimming it so the front is perpendicular to the frame - see the manual photo. I'll try to postbag photo later if I have one.
    edit: here's photo. I guess leaving some of the flange on would be good, just measure from the right place.
    Dan (RM1Sepex) found that when properly positioned the side panels are 8 inches from the rear door opening to the frame, as pictured:
  38. #158
    Pete'
    would it hurt to leave 5/8" of that flange?
  39. #159
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    We took the flange into account when we measured and positioned it. We will trim it off after we determine it's final location. We need to trim the door opening too. Once it is all in place we will mark all the areas where it needs trimmed with a sharpie then take it off and trim everything. I don't think we are going to cut it all the way back as is shown in the manual. I think we may leave a bit of that front edge, but it won't overhang the firewall and probably will be just a little short of it. It looks like Wayne left a bit of that flange on his. I haven't dug through the threads to look at others to see how much, if any, they have left.
    Larry
  40. #160
    I should have thought about leaving some of the flange.
    Larry, can you see the Ipad in bright sunlight? I'd like to put an Ipad into my console but I'm worried it might be hard to read the screen.
