this is my car pu 10-25-14 818s 03 wrx cruise power mirror wipers iwire harness
Wow, are you nearly finished already? You're going to have to post more photos and info than that!
Tamra
First autocross 3/29/15
What Mirror's are you using?
just figured out how to post pics will put some more up later that pic was from 11-30-14 I picked my car the same day you did I so you guys stuffing parts into your car and the kit was in the rental truck
I own a junk yard so I went out in the yard a took 5 sets to try ended up w 93-97 Honda del sol
Are you going to get it registered? If so, when's your date for inspection?
Tamra
What State/Country are you in?
Tracked May 27/July 26, 2017
Build Completed Winter 2021
north windham ct
