0
Originally Posted by
Bob_n_Cincy
Mike and I had time to work on our side shift transmission modification.
The reason for the side shifter is 2 fold.
With the side shifter, the shaft sticking out the back and some of the housing can be removed.
#1. For racers, allows for protective steel behind the trans and without the shaft it is less susceptible to damage from bump drafters.
#2. Opens up the space for my rear radiator.
Let me know if you have questions.
Chad
I agree with your comment on body damage. At least you can protect the transmission.
My 818s has no plans for wheel to wheel racing. If I get bumped in the back, it's going to crunch my radiator.
My next task is to seal up where the new shaft come out of the transmission.
