Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
Thread: 2002 WRX harness, pictures of each connector?
    Harley818's Avatar
    Vancouver BC
    Yes, I was just isolating it with heat shrink as you are doing.
    Just looking for confirmation that it is the right approach.
    There are a few situations where the normal state would be grounded so I am identifying those and I'll deal with those one at a time once I try to start it up.
    Its a lot easier now before I wrap the wiring and build in the shifter tunnel.
    Harley818's Avatar
    Vancouver BC
    Wondering if anyone knows what this is? Is it the ambient temp sensor?
    I am looking for the Ambient Temp sensor attached to F78. Connector is supposed to be two pin black. This one is * (neutral)
    If I find it I might leave it in, otherwise I'll delete it.
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    That's the power window circuit breaker.
    -Jason
    Feb 2014
    Asheville, NC
    I'm trying to remove some of the complexity on the car's wiring. Here's a big on I found that I'm convinced I can do without:
    The original starter circuit involves a relay to disallow starting the car if it's not happy about security (that definitely is getting bypassed), a switch for the clutch to be down (that's a pain in the *** as getting in/out of this car isn't as easy as a normal car), and a relay that locks out starting if the clutch switch isn't down.
    Here's the new circuit I propose for this:
    What's everyone think?
    Quote Originally Posted by Pearldrummer7 View Post
    I left the clutch switch and starter interlock in the circuit. I would hate to reach in to start the car and forget it was an gear. Then have it drive off without me.
    I left the starter interlock relay in because the clutch switch cannot handle the current pulled by the starter.
    Harley818's Avatar
    Vancouver BC
    I left the clutch relay in as well for the same reason..... don't want to have the car take off on me.
    I bypassed the security and the OS system and spliced the WB to the WR......bypassing both of them.
    Started it today for the first time.....after I grounded the clutch circuit .......worked like a charm.
    QC, Canada
    Does anyone know where I can find information on the purpose/use of each connector attached to the 2002-2004 steering column?
    I have the WIRING PDF for a 2002, but there are no pictures of the steering column and on the column's switches, no way to identify which connector name (B68, B78, etc.) refers to what. So I don't know which ones I can delete and which ones to wire up with my custom harness and other custom devices of my own I plan on fitting.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Frankfort, IL
    Frank - the easiest way I have found to identify connector numbers is to pick a wire that goes into the connector that is an unusual color combo and note it's position in the plug. Then do a "Ctrl + F" in the PDF file and search for that color combo.
    For example, there is a Light Green with Black stripe wire in the top right corner of one of the plugs that goes into the steering column. Searching "LgB" in the PDF file (kind of a poor example, because Subaru uses this color combo a lot) pops a result on page 50 of the PDF in the cruise control system and tells me that plug number is B68. I can then switch my search term to B68 and find all the places in the diagram that reference that plug number and note what each of the 5 wires leads to.
    Hopefully that helps a bit.
    QC, Canada
    Bill, good idea, of course it takes time, but we work with what we got. The colors are repeated multiple times but if the find function worked, one of them is what I look for. I'll try it!
    Frank, I am looking at the clutch interlock as well. I couldn't figure out the 2 switches on the clutch, after looking at your diagram (not the hand written one, the more complex Subaru one ) I think one is the security crap and the other the interlock switch. Good to know we still need the relay, I planned on dumping it too.
    Harley818's Avatar
    Vancouver BC
    Anyone know what this is for?
    I labelled it turbo, and the vacuum line is connected to the intake.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    That is your waste gate solenoid.
    also know as an ebcs (electronic boost control solenoid)
    Leesburg, VA
    Marked up my findings in bold. Similar to yours!
    I'm dieting my 2002 harness now and wanted to make sure I understood the consensus on the Integrated module. In order to delete it completely:
    On B280: Ground pin 4 (Black)
    On B281: Keep pin 16 (GrR) Lighting switch to B71
    On B281: Keep pin 18 (L) Lighting switch to B71
    On B281: Keep pin 19 (GR) Power to FB-20, Fuse
    Delete all other wires
    What do I do with the wires I keep? I'm deleting all the interior lighting but want to make sure I can illuminate the combination meter (dimmer not necessary). Would I need an on/off switch to ground on the two wires that run to B71? Can they be spliced to use the same on/off switch?
    Jaime also, mentioned wiring an on/off switch to GND on the Orange/White (on B281 pin 13) wire but this wire runs to the keyless entry module, which I already deleted. Do I need to worry about this OrW wire?
    Thanks for the help!
    Also, is anyone deleting the DRL system?
    Harley818's Avatar
    Vancouver BC
    I've cut my IM, security, and Keyless entry as well and plan to connect to power somewhere to light the instrument panel. I'm keeping my DRL though.
    Harley
    Feb 2014
    Asheville, NC
    Replacing the crap Subaru provides in the harness with heatshrink crimp connectors:
    What's everyone else doing?
    Jul 2012
    Encinitas, CA
    Yeah, I was surprised to see how splices were made in the factory harness... but it seems to work and it's cheap.
    I was planning to use the same, but I decided to out-source... I dropped my harness off with Brian (iWire) this weekend.
    I used post type terminal blocks with ring lugs on the wires. That way I could add wires as needed.
    Harley818's Avatar
    Vancouver BC
    If I'm lengthening or shortening lines, I'm splicing with Pico crimp connectors and their crimper, then protecting/insulating with heat shrink. This gives a good mechanical connection and insulation.
    The Subaru stuff I took apart all looked pretty clean and new given its 12 years old.
    Harley
    Mar 2014
    Edwardsville, IL
    I have a 2002 WRX. My car starts and the engine runs good, but I have a couple connectors that I need some help with. Pics below. Any help is greatly appreciated.
    Frankfort, IL
    the black one is B82 - Diagnosis connector. I kept it - just in case.
    The white one looks like B250 - Flash memory connector - also need to keep if you intend to reflash your ECU ever.
