Thread: Hydroboost line routing
    Swapping out hot wheels:) ironman16nc's Avatar
    Raleigh, NC
    HydroboostLines.jpgI've got a 4.6L with hydroboost brakes and power steering rack for a basic MK3 kit. I didn't pull the donor parts so I'm trying to figure out how the hydroboost (3 ports), power steering rack (2 ports not counting the ones that go to the rack itself), power steering cooling loop, and pump all connect. Can someone help me connect the dots (see attached drawing)? THanks!
    2019 Nov: '35 Hot-rod Truck, 306, EFI, 3-link (current build...the next possible 'keeper'!)
    2015 Mar: MK4 Complete kit #8617, 302 create, carb, 3-link (still wasn't the 'keeper car' LOL)
    2014 Sep: MKII Kit #4215, 302 create, carb, IRS, Sold as roller (wasn't the 'keeper car')
    2011 Mar: MK3 Base Kit #5400, 4.6L Fuel Injection, Complete! (well, just about)
    Raleigh, NC
    Found some more info...and I forgot about the reservoir. Can someone look at this and let me know if I'm on the right track?
    Stratham, NH
    Here's a great diagram and writeup on how to do it.
    http://www.ffcars.com/forums/showthr...ferrerid=26944
    Some of your fittings may be different due to metric vs SAE. Let me know if you've got any questions.
    Stratham, NH
    Cooling loop should be between I and J, in your diagram, on the low pressure circuit.
    Raleigh, NC
    Thanks!
    Thanks, John. That's a great link. I also noted in that discussion that I probably don't need to bother with the cooling loop. One less thing to find space for, mount, and have a potential leak.
    Paul
    Member ArcticSnake's Avatar
    Eagle River, Alaska
    Why do you have the "out" from the pump going through the cooling loop?
    Have the return from the rack and the HB unit converge into one hose-->through the cooler--> into the "in" on the pump.
    The cooling loop shoudl go in the small green line on the referenced schmatic (the low pressure return after the "T" fitting on the left side of the diagram.
    Dan
    FFR 6459, Basque Red Pearl, Silver Sky Metallic, 408W, TKO-500, Power by ISIS, IRS, PS, PB, 15" Pin-Drive, Loads of Extras, Loads of Fun
    Delivered Jan 08 - Graduation May 09
    Build Pictures
    http://s325.photobucket.com/albums/k...bra%20Project/
    Raleigh, NC
    Thanks. In doing some additional reading, I think I'll go without the cooling loop. Seems to be unnecessary unless you are pulling a trailer or in the Moab Desert. Neither of which apply.
