As my 818s is almost done, well with the kit atleast. Im looking to pick up an enclosed trailer and was wondering what works best.
Ive looked at a couple 14x7 trailers and measure the car and it should fit but i dont know if the smaller trailer, both width and weight, are worth the hastle of having to spuzee into a trailer. The door on the 7ft wide trailers is about 6 ft wide and my mirrors are only 6'4" wide but the fold in.
The other thing i was thinking about was how to secure it in the trailer, I got the Cabor fiber spliter which means the underside of the front of the frame is all covered my aluminum, how are you guys tieing the car down in the trailer.
The last thingis about getting in onto the trailer, can you drive in onto the trailer with out using the common 2x6s or are those ramp extentions a must have? (picture below)
Has anyone ever tried to put like a block or a 2x4 into the suspension to keep it from compressing after you have it jacked up. you would jack the front of teh car up, to fully extend the wheels then use a block to keep it there after you remove the jack. seems like you dont really need the suspension when the cars on the trailer anyways, and it would give you way more ride height to get onto the trailer. just a thought.
thanks guys
