0
0
I got my shifter and cable setup with a dry tranny and no hydraulics. Its notchy, but thats to be expected with no gear oil and the clutch engaged. One thing that helped was to get a feel for every gear location by shifting by hand at the rod... before hooking up any cables. I also had it in the air with wheels on so its easy to confirm your in gear or neutral by spinning a wheel.
