Man, it's been a while since I've updated this. I've been working a lot and just had my first kid, so I've been a bit busy.
With that being said, I have been able to get some work done on the 818. I installed the under battery and under seat aluminum a well as some of the front splash guards. I'm saving the nose aluminum and rear fender wells for when the body is back on to see how it's all suppose to fit. The under seat aluminum was a little difficult due to all of the bolt heads for the seat brackets and harness mounts. It turned out ok, but looks a little but like swiss cheese. Oh well, good enough. I coated these parts in 3M underbody spray, which is awesome but doesn't last very long.
The car now back off the lift and I started re-mounting the body, hopefully for the last time! I'm hoping that it all goes back on pretty easy since I already pre-fit it. We'll see!
