![Forte's](https://www.factoryfive.com/wp-content/uploads/2015/04/fortes.gif)
what part is this?
Guys, please go easy on me! I have looked through the manual but I can't identify this part. There is two. Looks to me like its to do with rear end.
Put me out of my misery please. Would you recommend powder coating?
That is a spring perch used with a donor built four-link rear end. They used to be welded in place, looks like a bolt-on item now. The Fox body rear spring would be shortened, the turned onto the perch, the bottom of the spring would set on the lower control arm.
Thanks! So with a complete kit, 3-link, these wouldn't be needed?
Not needed with the 3 link kit.
![Breeze](https://thefactoryfiveforum.com/attachment.php?attachmentid=40534&d=1428868052)
