Plumbing hydroboost and power steering, going by previous post with all fittings listed.
wondering if anyone has ever used a banjo bolt to an-6 off of power steering pump?
if so what fitting?
if so what fitting?
I just did it, but first call your PS pump supplier and see if they have the fittings you need.
I have the Frontrunner Drive system and the pump comes with the 6AN banjo fitting outlet Vintage Air part# 852011: http://www.vintageair.com/Instructions2013/904097.pdf. I busted the internal threaded aluminum fitting (weak point) and replaced that part with Detroit Speed's part, keeping the Vintage Air part with the 6AN fitting. Combined the two; worked well...just finished today...no leaks.
http://www.detroitspeed.com/Steering...e-fitting.html Of the Detroit Speed parts, I only used the crush washers and the threaded piece at top right (the VA part that I broke (over torqued...my fault).
