Results 1 to 30 of 30
Thread: brian b build #2
    Dec 2014
    north east ct
    brian b build #2
    here i go again I had a guy come up to me at open house he had health problums and could not complete it so he gave me deal I could not walk away from it #142 with A 06 STI DONER ALL THE CARBON FIBER PARTS RACING BELTS FFR SEATS AND STEERING WHEEL build #2 001.JPGbuild #2 002.JPGbuild #2 003.JPGbuild #2 004.JPG
    Good luck again!
    Mechie3's Avatar
    Lol, i'm still trying to finish #1.
    Wait...that's not really that funny considering it's mid July.
    Zero Decibel Motorsports
    Dec 2014
    north east ct
    if you were close buy i would be happy to come over and help you out seems like your spending to much time make people like spec parts
    The good thing is he's also making these parts for himself.
    Massachusetts
    Brian I used Trans Dapt locking hood pins on my engine cover and trunk. After I installed a few I realized each set has a different key. One set of keys has A2817 on it and another has A2036. I have two more sets unopened, no idea what the key # is for them. How do I get 4 sets with matching keys or how do I trade sets with someone?
    Davis
    Dec 2014
    north east ct
    davis all of mine are the same key # may be try returning the un used ones and try to get the same #
    Dec 2014
    north east ct
    well I had a good day sat got the frt tin done got most of the interior tin done de powered the rack ran the frt brake lines and clutch line rad hoses all in seat belts toup date build 2 001.JPGup date build 2 002.JPGup date build 2 003.JPGup date build 2 004.JPGup date build 2 005.JPG
    Massachusetts
    Dan. What is the name of the company that made your locking hood pins? What is the vendor that you bough them from? I bought them from Summit Racing and their locking hood pins all have different keys. Also I would like a solution to hinging the front hood. Give me your address and I will visit you when you have time.
    Davis
    Massachusetts
    Sorry, that last message was for Brian. Don't know where I got Dan from.
    Davis
    Dec 2014
    north east ct
    davis i got mine from autozone PART #PM1100E DID YOU WANT HOME ADRESS WERE THE 2 818S ARE OR WORK
    Massachusetts
    Whichever place I can see solutions for hinging the front hood. I don't really want to use 4 hood pins an have to take the hood off to check coolant. Thanks
    Massachusetts
    Brian. When you ordered the hood pins from Auto Zone did you specify you wanted them all keyed alike or do they just all come like that? The ones I got from Summit Racing have each set keyed differently. No way to order them all similar.
    Davis
    Quote Originally Posted by CU9DZ View Post
    You can't really check the coolant in the front. The engine is higher than the radiator, so it will just poor out.
    Check it at the Filler (degas) tank on top the engine, Mechie3 is making a real nice hood hinge, so you only need 2 hood pins.
    Massachusetts
    I have an overflow bottle on the drivers side of radiator. On the passenger side there is a nipple that used to go to the tank on top of engine. Do I have to plumb a line back from the radiator to the engine top tank or can I just plug the nipples. Also have a second overflow bottle. Should I connect the second overflow tank to the nipple under the cap on the engine top tank?
    Davis
    Davis
    The latest manual has you run passenger side nipple to the degas tank. No overflow tank in front.
    Freeport, ME
    Nice FFR photo, the crush brace needs to be on the other side of the bracket at the front for the inner fender aluminum to line up properly... Nice to see that they chopped off that nose support pad, mine were too long and too wide
    Dan
    Dec 2014
    north east ct
    they just came like that brian
    They now run the overflow line from the front rad nipple back to the rear overflow tank?
    No, They run the nipple on the radiator (pressurized) to the filler (degas) tank on top of the engine.
    The pressure relief valve on the filler (degas) tank goes to the overflow bottle.
    Dec 2014
    north east ct
    thats how i have mine and have not had any over heating problums at all so far got 850 miles on it build # 299
    Dec 2014
    north east ct
    ok so i went to dmv today the girl failed me 1 i had a buld for rt frt blinker blow out and the license plate lights were not out far enough she never chked brakes or wipers or ebrakes but real easy fix
    Awesome! You failed but the fixes are so easy it's like not failing at all.
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Nice! Not bad at all. We added spacers on our license plate lights to get them out enough.
    Be prepared for the brakes, wipers, and e-brakes next time - they tested all 3 on our car (although the things they test seem to be really random and do not follow the requirements list at all it seems like). For the e-brake, they had us pull it and then try to drive away against it.
    When do you go back?
    Tamra
    First autocross 3/29/15
    Dec 2014
    north east ct
    so they only chk the things that are stamped as failed on the imspection sheet the second time around but she did not tell me that i could not get my vin tag tell next week because of the office being closed for a week so i will go back monday
    Dec 2014
    north east ct
    Dec 2014
    north east ct
    Apr 2014
    Shelton, CT
    Nice! How'd it go at EFI?
    Tamra
    Dec 2014
    north east ct
    Not so good i had 3 problums 1 bad o2 sen , i have drive bye wire and it is going past 100% throtle and im losing fuel pres some were so i left the car there they are going to look at it to day
    Quote Originally Posted by brian b 36 View Post
    I had to add a stop behind my pedal
    http://thefactoryfiveforum.com/attac...1&d=1413755230
