Page 3 of 3 FirstFirst 123
Results 81 to 119 of 119
Thread: Gary's 818SEx4
    Jul 2014
    Strathroy, Ontario Canada
    Lookin good bud keep it rolling, I get dibs on the first ride! LOL I finally got my finishing kit, suspension is almost done. I almost have a roller.
    Ontario, Canada
    Quote Originally Posted by Lumpyguy View Post
    Hey Todd. Thanks man! Oh I'm envious of your progress! Glad u got ur kit and things are "Rollin". Got u down for first in the list.
    May 2013
    Colombia
    Hey Gary, any progress on your car? I've started some of the electronics, but nothing on the chassis yet.
    Ontario, Canada
    Quote Originally Posted by Speedy G View Post
    Hey Speedy. Thanks for checking on me. Sorry guys. . .been laid up here with other issues. Hardly touched the car. I'll be starting back on it soon. Been scratching my head over the battery choice for a while. Getting some new ideas here....
    Ontario, Canada
    Charger
    I'll be using the Lear 3.3Kw Charger(s) I have two and can charge at 6.6kw if I choose. These chargers are used in the Chevy Volt, Coda and I believe the Spark as well.
    Charge controller is Arduino based CAN controller to talk to the chargers. Charge voltage and current is fully programmable. This is from EVTV . . . the place u need to go for solid solutions.
    May 2013
    Colombia
    Very Cool... any news on battery choice or are you just waiting for new ones to get to market? I'm definitely going with at least 1 pack of 20Ah A123 pouches. I'm also thinking about taking the heat off the batteries through the connectors. I won't have them for another 2 months though.
  7. #87
    Apr 2015
    Andover, MA
    curious what a motor/gearbox unit like that costs? Great build!
  8. #88
    May 2013
    Colombia
    I just love the fact that the first 4WD 818 will be electric...
  9. #89
    Ontario, Canada
    Hey Speedy. Yeah I decided on using a Chevy Volt battery . It's actually quite powerful and will give up about 350kw. I will add another 24 Volts segment to it for a bit more range and headroom. I did want around 20kwh pack but 17.5 will do. I picked up a 2013 with only 1000km on the car, likely less on the battery. Essentially new.
  10. #90
    May 2013
    Colombia
    Wow, now that's a battery! Good placement too! Does that mean you'll have a frunk and a real trunk? Those motors don't take up that much space...
    Have you given thought to how you'll be shifting from park to drive or reverse? Will you use buttons or some kind of shifter?
  11. #91
    Ontario, Canada
    I don't know what I'll have left for space but I should have some room. I'm probably going to put a rad in the back so that may eat up some space.
    As for shifting, it will all be done by CAN control so could be either. I do have a rotary switch but I have t decided if I will use it. I rather like the shifter in my Volt as "low" is actually regen. I may have two regen levels/intensities. I like to use it often. I now have over 150 km on my volt and the brakes are like new.
  12. #92
    Ontario, Canada
    Gevcu motor controller
    This is the CAN motor controller. It can control other things also. It has two CAN Channels and some I/O as well. It's called GEVCU Generalized Electric Vehicle Controller. Again from Jack at EVTV.
  13. #93
    Jul 2014
    looks good Gary, might want to put a seat in there and make sure you are ok for leg room? you have a battery right where the fire wall goes, it loks like it will fit just make sure you ok with the leg room.
  14. #94
    Ontario, Canada
    Hey Todd. Thanks. Actually the battery just fits between the fire walls. There is about 1.5" at the back for it to sit in the design location. The front is a bit tight and has the cooling tubes poking thru. I'm more concerned with the width. Looks like I need to select one of the narrower seats to fit.
  15. #95
    Jul 2014
    Cool, good luck on the seats, I got the Large NRG seats and they just fit snug in the stock spot they are perfect for most people who sit in them not sure smaller would limit who can sit in it.
    Cheer
  16. #96
    Ontario, Canada
    Quote Originally Posted by ben1272 View Post
    Hey Ben. Thanks! The motor and controller is $6,500 and another 3K for the Borg Warner Egear drive. So about $9,500 at EVTV
  17. #97
    Ontario, Canada
    Cheer
    Thanks Todd. I need to get the seats next before I make a bunch of decisions on placement. The seat fit, along with the steering and pedals will need to be installed to help me decide if I will keep the battery running up the middle. I have room to move that part of it if I choose. That said, I want all the welding (I'm sure there will be some incidentals) done before I send it off for powder coat so that when it comes back it truly will be mostly assembly of items that all have a home. As you could imagine, with an EV there are unconventional components that don't have a defined home so, there are many options. Weight distribution and proximity to centre as well as elevation all play a role in handling. This weekend is busy but one after I will head to Toronto to check out some seats. . . where I can sit in them and measure etc…. gotta try em out!
  18. #98
    Ontario, Canada
    So I went to Toronto to try out some seats. Good thing too. I had my sights set on the Bride Low Max. No way. They are "made for 140 lb Asian guys" according to the shop owner. . .who just happens to be Asian, and he can't even fit in them.
    I just bought one seat and installed the steering column and brake pedal to get an idea of fitment and decide on battery. I think I will not put that battery section next to the seat. It's just too tight.
  19. #99
    San Jose, Ca.
    Hey Gary,
    Don't give up on having the center batteries. How about offsetting them slightly to the passenger side and just getting on of those tiny seats for the passenger.
    Jeff McCabe
  20. #100
    Quote Originally Posted by Gary Livingston View Post
    Gary,
    I'm 6' 300 lbs and my son is 6'3". We will have no batteries at all in the cockpit.
  21. #101
    Ontario, Canada
    Hey Jeff,
    I dunno man. I want a decent look as well. I can still keep the larger section in the tunnel ahead of the seats. I have a few choices where to put this block.
  22. #102
    Ontario, Canada
    Gary,
    HEy Bob, Ya I know you are a couple of big guys. I'm not so big. It is nice to keep the weight centred and low of course. I'm not saying its impossible. . . but it's not looking good. I could cut off the inboard lever for recline as there is still one on the outside. That'll save me an inch. Still thinking of console utility as well.
    There is room ahead of the front firewall, or right up front, or just behind the battery that is in the fuel tank location. I also want to add another 24volt segment. I could add it to one of the existing banks or get another set of end plates and place it separate.
  23. #103
    Ontario, Canada
    OK so, based on some of the feedback here, I took another look. I think I can make it work with the batteries in the tunnel if I mod the seats a bit. I'll need to remvoe the inside seat lever, probably modify the outboard one and make a dam close, tight, hugging cover for the cells through the middle. The pack is sitting exactly in the middle when the seat pics were taken.
  24. #104
    Ontario, Canada
    I should be able to create a nice storage space behind the seats also. My seats do recline and fold forward. The space above the battery could be used if the aluminum firewall was stepped instead of angled to create a shelf across the car.
  25. #105
    Ontario, Canada
    I kept the Volt battery tray and carved it up to use it for proper securing of these cells in the 818. I cut just the edge strips (bent form hook edge on one side and bolted clamp on other) for the segment that goes behind the seats. These will get welded in place. I then cut the two sections for the cells that will go in the console area ( I think). I had to excise these out of the tray and then separate the reinforcement steel by drilling out spot welds. Starting to tack weld in place.
    I have to modify the centre braces slightly for the forward section next.
  26. #106
    Oct 2014
    Redondo Beach, CA
    Very interested in how the center tunnel shapes up. I'm still using the 5MT trans so I'm trading a similar modification to the frame, but only placing batteries in between the shifter location and the front firewall. Where do you plan on mounting the electronics?
  27. #107
    Ontario, Canada
    Hey Nick. Well, I'm still deciding on some of it. The controllers have a fixed length connection that shouldn't be lengthened. The front motor controller will go just ahead of the front firewall. Luckily it fits in there. It will stand on end. The rear one will likely go fwd of the motor. I want to keep most of heavier items low in the car. The chargers can sit on frame work below the roll bar. Again, I'm thinking to squeeze them downwards. (as an aside, I have a couple thoughts on minimum weight that I may or may not pursue. One is to mount only one charger, 3.3kw, in the car for opportunity charging and the other on the wall at home and link them so I can do 6.6kw at home. Other is to use Batmod Vicors for DC/DC instead of Coda unit.) I will also mount a radiator with dual electric fans, and am planning to wedge it in the back of the car. Other electronics like the charger controller and GEVCU will mount on the frame under the roll bar.
    Most of this is a vision at this point.
    Cheers.
  28. #108
    Ontario, Canada
    few pics
  29. #109
    QC, Canada
    Wow really nice! A lot of space after the engine fitted. But no pix of the front yet?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  30. #110
    Ontario, Canada
    thanks Frank, Ill take a few pics of the front .... just for you.
  31. #111
    May 2013
    Colombia
    Man, in your case, I think it might've been easier to start out with a no-frame kit. I hope Dave is checking this thread out. How cool would it be to have FFR do an EV kit from the factory, using your project as inspiration...
    Btw with the batteries in the middle, have you figured out what seats to get? How wide is your "battery" tunnel? I'm thinking of using A123 20Ah pouches, so a battery tunnel like yours seems very appealing, but I'm wondering what seats to get.
    Hey no paint on the frame or do you still have to disassemble, paint and reassemble?
    Speedy G
  32. #112
    QC, Canada
    Hey Gary, way too long without an update on this 4x4 build!
    What changed since Nov?
  33. #113
    Jul 2014
    I live an hour from Gary and have emailed him a few times and he has not responded. not sure how he is doing
  34. #114
    Feb 2014
    Southern California
    any updates on the 4x4 build?
  35. #115
    Ontario, Canada
    hey guys. I must apologize for being MIA. Lots has changed. I haven't touched the car. I moved. New place, separated etc. You know the drill. Anyways, just finishing to insulate the garage so I can work through the winter.
    Sorry Todd, I also lost one of my email accounts. Anyways, I'm back on my feet now. I seem to be doing a lot of apologizing lately....
    Don't look for much in the very near future but I will be getting back to it. I have a lot of catching up to do with everyone's threads.
    Gary
  36. #116
    QC, Canada
    God damn Gary, I'm so sorry about all those bad lucks.
    You do have a lot to catch up and on your own build as well, since we are very interested in seeing updates, we will be patiently waiting for you to be up and running.
    Take it easy!
  37. #117
    Jul 2014
    Man good to here you are back, I was a bit worried. have to get in touch soon.
  38. #118
    May 2013
    Colombia
    Gary! Great to hear from you. Sounds like you need a cool hobby right about now! Oh wait, you got one! Just think about the blond that's going to sit next to your next summer. That'll keep you going!
    Speedy G
  39. #119
    QC, Canada
    Hey Gary, you back on track?
