Thread: transmission tunnel
    Mar 2015
    Belmar, NJ
    transmission tunnel
    Did anyone else have trouble with transmission tunnel?
    no issue if I install it without the rear firewall
    with the rear firewall in place I am unable to get it all the way to floor. Any suggestions before my files and grinders comes out?
    Maybe some pics of your installation
    thanks
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
    Feb 2014
    Asheville, NC
    I hacked everything up to make it work. Grab that angle grinder!
    QC, Canada
    I had a LOT of troubles with the tunnel cover, I had to trim it virtually everywhere and every corner and yes it seems a little too long to fit with rear FW. I haven't done the trimming yet but that will be my solution. Trimming is what I do for a living on this build.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Senior Member suttonb3's Avatar
    Tampa, Florida
    I also performed a lot of surgery to get everything to fit.
    Kit #295 Picked up 11/26/2014!
    Senior Member R.Spec's Avatar
    Portland, Oregon
    I test fit an am going to have to trim a lot as well.
    R818s | Gt35r| Forged 2.5 | Q16
    Kit Ordered 4/14 | Kit Arrived 1/15
    First Start 8/29/15 | First Drive 9/7/15
    Freeport, ME
    I hacked and replaced almost everything, it is in progress and about 2.5 inches taller.
    I think I should have just cut it out and installed my own, cleaner. I don't need all the space with the iWire harness
    Dan
