Any plans for one with a roof? Timeline?
Martin
Martin
Previous forum name was "Fezzek"
In the original coupe thread this was discussed, and the consensus at the time was that there is not enough room for a roll cage with the coupe roof.
Owner: Colonel Red Racing
818R ICSCC SPM
Does that mean no R version with a top ever, or just that the current top does't fit the R model.
I thought they might still do a coupe version of the R but it would be a different style of roof?
Martin
Anything is possible, but FFR has made no mention of such plans. At the moment, you're best bet is to modify the roll bar yourself to work with the coupe roof.
keep in mind the take rate on the R in general is a lot lower than the S (4 to 1 maybe? I know Dave mentioned it a while back). Add to that the fact that getting in and out of the R if it had a hard top means you have to wiggle through the window, and the take rate would likely drop even more (R hardtop vs S hardtop). With this in mind, the economics are going to be hard to justify and I suspect you will be waiting a long while for a factory developed R-specific hardtop.
Thanks for the information and advice. Will have to mull this over some more.
Martin
After having driven the Daytona coupe I can't imagine having a R version of the 818 and trying to get out of the car in under 45 seconds (if at all) for safety reasons or change of driver, seems like you would have to be pretty small and agile for this to work.
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
And I am not small....
The GTM comes from the factory with functioning doors. People choose to add door bars as appropriate. Much different than Factory Five having to both add tooling for a special hard top and having to add tooling for a special 818R coupe frame. Again, not saying it can't be done, just saying I don't see the return on investment being there for FFR when they are already selling all the 818's they can make.
Also, the GTM is quite a bit larger than the 818.
I looked at fitting a cage in the hard top. Had to see it for myself so I took a trip too FFR to see it in person and concluded that the window is not big enough. If you have a head restraint seat and a han's device it would be tough to get out of the window, even if you cut the top of the doors down to the top horizontal bar on the cage. I ordered an R kit.
Just had to comment on this. If someone is serious about a coupe racing version, it would be worth the effort to create an escape hatch similar to the funny car dragsters in NHRA. I think the modification of the halo would be pretty straight forward for the existing roof but ingress and egress would be a completely different story. I have never seen those guys getting in the funny cars but I know they always pop out of the hatch especially after winning a race. So this method would probably meet safety requirements. Plus it would be pretty cool to enter and exit through the top. Maybe you should ask Jim about that. I think FFR likes innovative solutions.
WEK.
Here you go
http://www.foxsports.com/nascar/shak...lladega-050413
Does anybody know if there is steel in the coupe's roof? Does it offer more roll over protection than the 818S?
Well- what if they utilized functioning doors (like in the road-issue 818C) and then sloping side-impact bars? Would that not work?
I'm sure you could use a minimalist or partial-width dash, to improve leg clearance too.
OR - what about a central seating position, like in the McLaren F1 ?
I already have a center drive single seat 818C planned out. Extend the the pedal box forward, center pinion rack and pinion steering, build a cage under the hardtop (do not install inner top liner). have opening doors with door bars that extend into the door skins.
Thanks- Chad
Yes, start with an S and build a center drive. I talked with Jim about that 6 months ago
Any word on whether FFR is considering offering something like this Wayne ?
I know they are not doing a center drive 818, and I do not know if they are planning an 818RC or not.
I saw some pictures here on the forum somewhere of another builder who did a center drive. I think it would be interesting, even for a street car. McLaren F1 like. I wonder if there is room to do the flanked passenger seats? Would also be a great application for a-pillar hinged or gull wing doors, with the doors including a chunk of the wide sills. Would make entry and exit easier if sill was lifted up with door.
This one?
http://thefactoryfiveforum.com/showt...-on-Track-Pics
It doesn't look like there would be any room for passenger seats unless you got really creative.
Drag racing safety rules are completely different than road racing safety rules. With a roof you need a high front cage, so the current low front R cage would not be legal, even if the C roof would fit over it. A high front cage requires a triangulating or x brace in the plane of the roof, so no way to fit an escape hatch.
