Results 1 to 11 of 11
Thread: FFR 818 for sale
    FFR 818 for sale
    Professionally built FFR 818 for sale. Kit number 33
    base kit with the following FFR options
    Powder coated frame
    steering wheel
    padded dash and door panels
    harness bar
    front and rear carbon pieces
    windshield wiper kit
    trunk insert
    Donor:
    2002 WRX with app 120,000 miles
    All parts were cleaned or replaced if damaged.
    engine was cleaned and replaced timing belt, and all gaskets
    trans was painted and works perfectly.
    all four suspension corners were replaced with 2004 STI units.
    Car has special built DSS CV axles to adapt the trans to the STI knuckles
    Brakes:
    STI Brembo black calipers and rotors
    4 piston front
    2 piston rear.
    New rotors
    stainless brake flex lines
    Suspension:
    Subaru aluminum front control arms
    STI knuckles
    Aluminum rear lower control arms
    adjustable links
    interior:
    Fully carpeted and insulated interior.
    one off console to house the radio and switches
    Corbeau racing seats on semi adjustable bases
    4 point harnesses
    E-Stopp electric parking brake (no visible handle)
    radio with 4 speakers
    Waynes custom billet shifter
    stock gauges
    Cooling:
    aluminum radiator with shroud and dual cooling fans
    cooling tubes front and rear
    cooling fan over ride switch
    waynes cooling mod.
    Exhaust:
    3 inch stainless system with cat. Comes straight out the back.
    Wiring:
    Car was wired using a Painless 12 circuit wiring harness to handle everything
    except the engine. No more bulky factory fuse boxes
    engine was wired by harvesting the engine only wiring from the donor harness.
    I then integrated the 2 together. Everything works as it should.
    I am sure I am forgetting a bunch of stuff.
    Car is currently registered and driving with no issues. However it does have a rejection stick and am currently going through the MAC center to get a good sticker. It has been over 2 months since I brought it there and they still have not issued an OK to get a sticker.
    Pictures can be seen here of the build.
    http://thefactoryfiveforum.com/showt...plicaparts.com
    Asking $20,000.00 FIRM. You cannot build on for this price.
    nkw8181's Avatar
    Dallas, TX
    Sad to see you sell it
    Nolan
    wallace18's Avatar
    Trenton, Florida
    That is a beautiful car at a great price. Mike you did a great job building that car, IMO. Someone is going to get a bargain on a car that would cost most likely a lot more to build for sure. Best of luck.
    Bump to the top. If it doesn't sell, I will be changing the nose and adding the hard top.
    Just lowered the price. Really could use the room. (my Z06 is out in the cold)
    Thanks Mike
    Still available. Will be at Moochfest weather permitting.
    Jul 2012
    St. Augustine, FL area
    Very nice build
    Sgt.Gator's Avatar
    Bend, Oregon
    I read your entire build thread. Awesome build. If I was looking for an S I would be all over this one. But I'd rather start with an R rather than ruin a well built S making the mods. I'm still considering how it could be done though.
    Looking at the quality of your work, I should pay you to make the mods!
    Question: The insulation/sound deadening, it looks like the lightweight foam filled stuff, not the tarry dynomat that weighs a ton and sticks like welded steel, correct?
    GLWS!
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Interested in any trades? I am local.
    Sorry Sold
