0
0
5L Coyote Engine build using a F-150 5L Engine as a base
Started working on blueprinting our 5L engine which came form a donor F-150 Platinum pickup. Got the motor form Standard Auto Wreckers and started to blueprint the motor to determine what the starting RWHP would be as is then go ahead and rebuild the top of the engine to allow us to get past the 400 RWHP mark at a minimum. Attached are pictures of us starting the blueprinting process.20151024_154218[1].jpg20151024_154223[1].jpg20151024_154235[1].jpg
