20
104
nkw8181
Geeezz that's huge! When looking from the back with the tires on the majority of the with will be tire.
That's the idea! I can't wait to get tires and put this on the ground.
Pearldrummer7
Those are huge. Will the tires touch each other with how wide they are?
Your backspacing is a lot less than mine (~10mm less clearance on the inside). How does that work? Do you have a spacer or something?
My 17x9 + 35mm offset rubbed in a few places until I added a 3mm spacer. That's with Wayne's modified arms.
No spacer yet, the suspension bolts are all loose, hanging, with the coilover preloaded.
Kurk818
The clearance on mine is also just as tight. So much so that i had to switch from the rim mounted balancing weights to the stick on type to avoid the contact with the upper trailing arm during cornering.
Love the wheels
Thanks Kurt, I'm really happy with them. I'll have to remember to get the stick on weights, I definitely don't have the room for the hammer on style.
Adam _____ Instagram @PopesProjects____
YouTube Channel
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
