Results 1 to 5 of 5
Thread: Radiator replacement in MKII
    Is it necessary to remove the body to replace a leaking radiator in a MKII, or can it be removed from bottom of car? '93 5.0 drivetrain and cooling system.
    Kirkland, WA
    Quote Originally Posted by funk289 View Post
    Depends on how the builder installed the radiator but it should be totally possible to drop it out the bottom
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    "The I.E." SoCal
    I just went through this on a car i'm working on right now. The owner siliconed all of the nose aluminum in when he installed it. I had the body off already but it was a bear, I can't even imagine trying to get the aluminum panels off of there with the body still on the car. As it is, I had to fab up all new aluminum panels for the nose since I nearly destroyed them getting them removed. If in fact, the aluminum is just riveted in you should be able to remove it and slide the radiator out of the bottom as it was suggested above.
    __________________________
    Just did this last week. It will come out the bottom. removing the shroud will help.
    Thanks for the quick replies. My panels are riveted and radiator is bolted. Looks like it will slide out the bottom without too much hassle. Thanks Again.
