Results 1 to 40 of 69
Thread: Interest Check/Group Buy: Steering Rack Extender, Zero Decibel
    Mechie3's Avatar
    The early chassis have the mounts for the steering rack in the wrong position placing the rack off center. I don't know how many chassis are affected or what chassis number it was fixed at. One of three things could be done:
    1: turning radius left/right was different as the stroke left/right was different
    2: minimal thread engagement on the tie rod end,
    3, make an extension
    I made a couple of steering rack extenders (C. Plavan, Bob n Cincy, RM1Sepex, myself) and finally got them quoted at a third party shop so I can actually sell them (vs just giving things away, lol).
    Machined from 1018 steel
    Here's a picture of an old prototype on Bob's car. I've changed it slight to allow for easier installation.
    Group buy pricing, min 5 required to order. 50% deposits due before ordering (only so I don't get stuck with several hundred dollars worth of parts I don't need). note: the price drop between 5 and 10 pieces is rather substantial and tapers off from there. At the 5 piece price it looks like a majority of my cost is just amortizing the setup fee. After that it's more machine time and material.
    5-9: $140
    10-14: $95
    15-20: $77
    20+: $64
    1: Nismo_RB25
    2: Metros
    3: Jrach
    4: Ethan818
    5: Rori
    6: Justin
    7: Justin
    8: Azpete
    9: Santiago
    10: Santiago
    Zero Decibel Motorsports
    Freeport, ME
    Craig, this piece is inside the boot, can you quote out of reg, non stainless steel?
    Dan
    Mechie3's Avatar
    Good point. Asked them to requote in plain carbon steel.
    Adkins, TX
    You can count me in for one. If you don't get enough to make the minimum I will order two just so I don't have to come up with another solution.
    1995 Nissan Skyline GTR VSpec
    818S in progress.
    Senior Member metros's Avatar
    NoVA
    I'm in. Cheaper steel preferred.
    Member JRach's Avatar
    Seattle, WA
    Correct me if i'm wrong here...
    But if the steering rack is off center by a little bit, this shouldn't effect the turning radius if the tie-rods are adjusted appropriately. Yes you'll have more threads/adjustment available on one side when compared to the other but turning radius is only effected if someone slaps the rack in place and then puts the steering wheel on not centered with the rack (lock to lock) to compensate.
    With that being said, I like having a little more peace of mind that comes with additional meat/threads on my tie rod ends. Count me in for one
    1998 Subaru Forester
    Full 06' STI conversion
    Twin scroll low mount headers
    HX35/40 turbo, ITB Custom intake manifold
    Mechie3's Avatar
    The issue wasn't so much how much adjustability you have but that the side with fewer threads didn't have very many threads total engaged.
    Freeport, ME
    Check out my build thread starting on or about post 398 and read a couple pages. http://thefactoryfiveforum.com/showt...-Thread/page10
    Basically we found that our early chassis had the rack mounted too far to the driver's side by .55 or so... never could get FFR to provide the exact information. this post summarizes the situation best:
    http://thefactoryfiveforum.com/showt...-Thread/page12 first post # 441
    all the early cars gave up wheel rotation to one side, reducing turning radius in one direction (doesn't give a tighter radius in the other direction, the tire rubs vs the aluminum.)
    I have no idea if or when this was resolved by FFR
    Dan
    I have an early frame and have found this issue as well. Count me in for one as well. Cheaper steel also preferred.
    USA
    I'm Chassis 73 or 74 and don't recall having this issue. I can't say definitively at this point, but maybe others can chime in so we know when it was fixed.
    Mechie3's Avatar
    Updated pricing for 1018 steel. It wasn't much cheaper, just a little.
    Chicago, IL
    Looking forward to the new quote.
    Executive Director
    The Community Garage
    Mechie3's Avatar
    I updated pricing up above. The entry level price dropped ~ $20. Next one dropped...$25?
    Adkins, TX
    That's good news for the guy who might be buying a paperweight.
    818S in progress.
    Mechie3's Avatar
    At this point I would buy one or two for myself for inventory. I just left your name there so it shows we hit the 5 limit.
    Adkins, TX
    Woot! That just means I get to buy a bunch of other things from you. Don't anyone tell the wife.
    818S in progress.
    rori's Avatar
    Tulsa, OK
    I'm probably going to need one of these. Put me down for one. I hope we can get to that 10 person discount.
    Mechie3's Avatar
    I typically post these once or twice on facebook just to make sure it gets the most traffic. Letting others know what products I have is certainly my biggest challenge.
    Tucson, AZ
    I might need it, not quite sure yet. I'm pretty sure my drivers-side wheel is inward by about 1/4" - 1/2" though, if that is the symptom.
    Quote Originally Posted by bompus View Post
    The Symptom you will see:
    Turn the steering wheel lock to lock.
    Clamp your steering at the center of travel.
    With both your UCA adjusted to the same length.
    Adjust your front wheels until pointing straight ahead.
    The thread engagement of the steering tie rod ends should be equal on both sides. Less than a 1/4".
    Here is a picture of my old car. notice the steering rack bracket overlaps on the drivers side.
    The next picture is a newer correct frame.
    notice the steering rack bracket has a gap on the drivers side.
    NoVA
    Mine seemed equal when installing the rack. I'm really interested just for the peace of mind in having a lot more thread engagement.
    AKA - newer chassis owners - don't dismiss this product because you have a newer chassis.
    Denver, CO
    I am in
    Mechie3's Avatar
    I'll leave this open for a few more days then place the order. 4 more till its $45 cheaper.
    Freeport, ME
    Quote Originally Posted by metros View Post
    If there are significantly more threads on one side than the other your rack isn't centered. What serial # do you have?
    Dan
    NoVA
    ^Which is why I said 'mine seemed equal' in reference to the number of threads on each side. It just doesn't seem like enough to me. This is an easy solution.
    San Diego Ca 92106
    Not sure if I need it yet. I have frame # 253 and haven't mounted the rack yet. I'll find out soon though. Soon enough for this batch... Can't say
    Senior Member AZPete's Avatar
    Craig, put my name on one, please.
    Pete
    Denver, CO
    I have close to same number and I worry by how little thread engagement there is on my 2006 rack at both ends.
    Denver, CO
    Same here. Not much engagement on both ends to make me feel comfortable.
    San Diego Ca 92106
    So are you saying you need an extention for each side?
    Mechie3's Avatar
    Justin us in for two. At that rate I'll knock it down to the $95 price.
    Freeport, ME
    If I centered my rack the right side had only 4-5 threads engaged, with the spacer both sides have more than an inch, plenty of engagement.
    Dan
    Denver, CO
    Isn't this for two? That is what the newer kits need. If it is this cost for only one, I will opt out
    Mechie3's Avatar
    Its for one. Cost is high because of low quantities. If it was for two I'd be losing money.
    Mechie3's Avatar
    I dont recall offhand but I think the spacer is a little over an inch long. In a new kit if you added one it could be aligned to split the difference left and right. Not sure what happens to total turning radius though as if the wheel hits sheet metal on both sides before lock it doesn't change effective radius.
    Freeport, ME
    IIRC it is 1.1 inches. If you were to add one on each side you would have some serious bumpsteer as all 3 pivot points should be in a line for zero bumpsteer
    Dan
    Denver, CO
    I understand, that makes sense.
    San Diego Ca 92106
    When is the closing date for this group buy?
    Craig, please see post #27 and add me to your list on post #1. I don't want to miss the boat.
    Chicago, IL
    I'm in for two. So that should bring us to 9 total - c'mon people!! Just one more to jump in on this and we cut $45 off the price of just one (and I save $90!)...
    Best,
    -j
    Executive Director
