***New racecar on the way*** I do not need three racecars- Make reasonable offer, PM to discuss.
818R Chassis #44. You know the car. The first non Factory 818R raced on the West Coast. Comes with NASA log book and 2015 annual tech. Non donor build, 95% all new parts.
2.5L AJW built block (Forged pistons- 2013 STI block with 2006 wiring harness etc.)
5 speed Legacy GT transmission (thicker gears than WRX) with Modena TBD LSD (top of the line) and another spare Legacy GT transmission.
Blouch DOM 1.5 XTR turbo (DE-Tuned for 283HP on 91 pump gas for ST2 class HP/WT limit) Can easily tune to 400HP+ safely.
Injector Dynamics 1000cc injectors
Tial EWG setup with custom exhaust and dump tube (dumps into exhaust)
Wayne's AWIC complete kit
iWire's complete wiring harness setup with push button start
Element Tuning's Complete Dry Sump kit with all -12AN fittings and SS braided lines
Setrab oil coolers
Mishimoto Aluminum Radiator
Aluminum coolant pipes (not the crappy stock ones)
Red Wilwood brakes front and rear with dash mounted bias control
Racetech halo seat
Complete in car SFI/FIA fire system plumbed to driver,fuel cell and motor)
Additional hand held fire extinguisher mounted under seat.
Fuel Safe 17 gallon Pro fuel cell (Aluminum upgrade, one way fuel box inside (no fuel starving in corners), In-tank fuel High performance pump, fuel level sender) with custom aluminum enclosure in passenger seat area (Much safer location, and better weight balance)
2 sets of Team Dynamics race wheels 17x8 front and 17x9 rear.
Front carbon fiber splitter with struts
Carbon fiber front dive planes
Rear Carbon fiber diffuser
GTM-300 APR wing with Gurney flap
Upgraded springs front and rear (way better than stock)
Cobb EBCS
K-tuned shifter
Schroth 6 point belts (new)
Custom rear wing mount/bumper
Custom drivers side intrusion plate for safety
All of Mechies bits and vents
Alot of custom parts. I built the car for safety in mind.
Car is ready to go. It is faster than Lotus 2- Elevens (with the 283hp tune @ ~2266 pounds including driver- with ballast)
$25k/Offer PM me to discuss.
Please keep in mind I'm still messing with it. It's not a garage queen. The price may go up after a few weeks once I dial it more in (new 10cm oil pump going in to cure oil heating problem).I'm not in a hurry to sell, but I have my eye on another project.
