10
65
View Poll Results: How to finish the mesh panels?
- Voters
- 57. You may not vote on this poll
Gloss Black
Unfinished Aluminum
Bob_n_Cincy
Mike, Looks good.
Is 500 psi enough? I thought pressures go up to the 1300-1500 psi levels.
Good Question, Bob! I did some (back of napkin) maths to estimate line pressure from a formula I found on some web site which estimated ~360 PSI, but admittedly it's an internet formula and math isn't my strong suite... I have exploded one (500 PSI) transducer already when leak testing the brake lines. If I pop another one I'll be upsizing (and redoing the math) :|
Hindsight, I'll let you know when I work it out . Actually I'll be using an ebay flock-it-your-self kit (go figure), which consists of acrylic paint, the actual flocking material, and a squeeze bottle for depositing. If it works out properly I'll post the information up.
