Page 3 of 3 FirstFirst 123
Results 81 to 100 of 100
Thread: ez30r questions
    I have a system that will do drive by wire, AVCS, and has built in traction control. It's $2950 with the car harness.
    That's for the ez30r?
    Go on! What ecu management?
    Jan 2012
    Behind door #3 is the.... tec3 ecu system.
    Did I win the grand prize?!?!?!
    Nepa
    Wayne, your system includes a fuse box and wiring for all the cars systems? Is your system plug ands play for factory gauges?
    San Diego Ca 92106
    Here is a H6 resource thread on nasioc...
    http://forums.nasioc.com/forums/show....php?t=1323800
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Quote Originally Posted by craigfree View Post
    It's the New Haltech Elite 1500
    Quote Originally Posted by Samiam1017 View Post
    Yes it does
    Isn't the Haltech elite 1500 for four cylinders?
    What’s different:
    • Elite 1500 is ideal for 4 cylinder or 2 rotor engines.
    It has 4 fuel and 4 ignition outputs and single knock control.
    • Elite 2500 is ideal for 6, 8 cylinder or 3, 4 rotor engines.
    It has 8 fuel and 8 ignition outpus and dual knock control.
    My wiring plan at the moment is the elite 2500 with painless for the chassis, which is just under the 3k price.
  7. #87
    Administrator
    Enterprise Alabama
    You can run the 1500 on a 6 by pairing injectors and running wasted spark.
    I'm a Haltech dealer so buy it from me please
  8. #88
    San Diego Ca 92106
    Would the 1500 run the ez36 too?
  9. #89
    Administrator
    Enterprise Alabama
    Yes it will
  10. #90
    San Diego Ca 92106
    Ok, on the Haltec website their video of the elite 1500 and 2500 says that the 1500 will run 4cyl full sequential and 6cyl semi sequential. What does that mean and should I care?
  11. #91
    Nepa
    this maybe a stupid question but I don't know the answer, are multiple injectors firing but just not entering spark too? or isn't that what's happening.
    and whats the upgrade cost from the 1500-2500 thx
  12. #92
    Administrator
    Enterprise Alabama
    Semi sequential means that it is running the injectors. Up on the cylinders that are going up and down together. They will run just as good as a fully sequential system up and to the point where you have such a large injector that you had can't have a short enough pulse width to idle
    On the paired cylinders, the spark fires during an exhaust stroke on one side and firing stroke on the other. The cost difference between the 1500 and the 2500 is $500
  13. #93
    San Diego Ca 92106
    Thank you Wayne, sometimes the most basic things can confuse me.
  14. #94
    Brisbane, Australia
    Hi all EZ30 guru's
    After a burst of impulse buying at an online auction site I'm now the proud owner (until the wife finds out) of a slightly damaged 2006 Outback R with the 3.0R motor
    It isn't going in my 818R straight away, as my approval to build is for the 2006 wrx motor, but I'd really appreciate if someone could point me to a link for any relevant factory workshop manual
    Cheers
  15. #95
    San Diego Ca 92106
    Nepa
    I ordered Wayne's haltec unit and will be running it on an 07 wrx. I purchased a 08 legacy EZ30 to rebuild and install next winter. Haven't decided if I will run a turbo supercharge it or just run it NA.
  17. #97
    Brisbane, Australia
    Awesome, thank you
  18. #98
    San Diego Ca 92106
    Your welcome. This covers up to 2008, if anyone has a link for one for the ez36 2010 and later I'd appreciate it.
  19. #99
    Senior Member DSR-3's Avatar
    San Jose, CA
    maybe here?
    http://jdmfsm.info/Auto/Japan/Subaru/
  20. #100
    San Diego Ca 92106
    Thanks, so far from a cursory look it looks like what I need.
