Thread: Prepping a donor before moving
    So, I have a plan to eventually build an 818C using my current daily driver 2005 WRX.
    Soon, I'll be making a move that will just be for one year, but I will have lots of time off and was considering going ahead and doing donor prep. Does this seem like a good idea? Or would it be a terrible idea since I'd have to scoop everything up and move it before being able to build the kit?
    Thanks for the feedback!
    Jul 2012
    Encinitas, CA
    The donor parts required are really not that numerous/cumbersome; besides the the motor/trans, nothing else would be too difficult to move if you're organized. If you're committed to building an 818, and confident you can complete the tear-down, and sell off and/or dispose of the unneeded parts (including the body) before having to move, then take advantage of the time; it's good to start the build with your donor parts already stripped and prepped. However, it would be a RPITA if you're only half-way through the process and have a partially stripped car and big pile of unneeded parts you have to move.
    Bowling Green, KY
    Having done what you are contemplating, moving after donor tear down before my kit arrived. It wasn't too bad, as Wheehenrick points out sell off parts you won't need before the move. I picked up a bunch of plastic stackable bin's to store parts before and after prep. I kept related parts together, Label everything. Keep all nuts and bolts you will need from the donor with the part you will be using from the donor. Keep all the nuts and bolts you take off, I separated them by size and thread pitch, you never know what you might need late at night. If you think you might need it keep it.
    wallace18's Avatar
    Trenton, Florida
    Here is a picture I took of 90% of the donor stuff ready to install when I finally got my first 818S I built. It will give you an idea of how much we are talking about.
    My first piece of advice is.
    Don't take apart a running 05 WRX.
    I picked up an coparts 05 FXT 90K for $2500.
    If your situation changes after a year, you will only be out $2500 or less if you sell off all the un-needed parts.
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    I'm with Bob. A running WRX is an asset. Don't tear apart a good, running, car. Sell it if you must and buy a crashed out something.
    Fast Cars, Fast Women, Fast Haircuts!
    Thanks for all the input. It makes a lot of sense! My thought on using my running WRX is more of a sentimental thing since I bought it new and thought it would be nice to carry it on. But financially, what you all are saying makes a great deal more sense.
    I've really enjoyed following all the build threads here and am amazed at what everyone has accomplished.
    Thanks again!
