Page 3 of 3 FirstFirst 123
Results 81 to 99 of 99
Thread: Double axle failure on the AEM 818R
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I'm not positive but since they offer the extra-strong axles with new hubs, I believe the hubs will fit the existing spindles and bearings with no boring required. I'm sure they just machine the inside of the hubs out and then machine new splines so that the inner diameter is larger and the splines count is optimal. That will probably make the hubs a bit thinner but I assume that's not an issue nor where the weakest point is.
    Hindsight nailed it. You cannot put bigger bearings with Subaru hubs, there would be no more metal left. They just bore the inside of the hub and machine new splines.
    I should get my axles Tuesday or Wednesday, I'll post pix.
    Senior Member BrandonDrums's Avatar
    Triangle area, NC
    750hp was a great figure. I suspect 500 hp axles won't cut it for me.
    I wonder if it's 500hp per axle or both Have them send you a free pair to try out and perhaps you can report back haha.
    I wonder if there are any larger subaru spindles that will be comparable in bolt points that could be used. The Tribeca and Baja in particular come to mind. Might be worth a look through www.opposedforces.com to see if they fit the bill.
    You have to pay to play. Launching with slicks will cause breakage, get better axles then you have tranny issues as you all know. Launch with slicks and understanding what the lack of mechanical sympathy does typically leads to expectations be realigned, expectations is typically the biggest thing that typically needs to change. . There is no cheap solution to 400 HP and slicks as much as people hate to hear that. One can back off a bit or fork out more money of your truly serious. If you are here you go. Good news is they have the for the older lighter 5MT from the WRX as well. Of course then there is case flex issues. You can also look into case braces they have them out of NZ. Been there done that. 11 years ago. Good luck!
    http://www.mrtperformance.com.au/per...able-gear-sets
    nkw8181's Avatar
    Dallas, TX
    Sixstar how did you fit 285's?
    Nolan
    Got my axles and hubs last Tuesday:
  7. #87
    nkw8181's Avatar
    Dallas, TX
    Is it not a male to male axle??
    Nolan
  8. #88
    Leesburg, VA
    Quote Originally Posted by nkw8181 View Post
    Frank is running the G50 transaxle, not a subaru trans.
  9. #89
    Tech Support, FFR Courtnie Provencher's Avatar
    Only somebody with a race car could find excitement in parts breaking, I love it! Keep pushing forward!
    Courtnie Provencher
    Factory Five Tech Sales & Support
  10. #90
    nkw8181's Avatar
    Dallas, TX
    Sorry had an aha moment. Is DSS a vendor?
    Nolan
  11. #91
    Don't think DSS is a vendor on this forum but they source the FFR shafts for the 818, as what I've been told.
    Yes, I'm running a male to nothing axle, as I don't consider the G50 inner CVs are either males or females. lolll
  12. #92
    Denver, CO
    You mean one side is genderqueer
  13. #93
    Orange, CA, USA
    Looks like it would be called a flanged end to me.
  14. #94
    Yeah genderqueer.
    It's just a flange that you bolt to the flange on the gearbox. 6 50mm bolts.
  15. #95
    Denver, CO
    Sorry, got a little carried away, anyway...
  16. #96
    Feb 2013
    Westminster, MD
    Nolan,
    Sorry for the MASSIVE delay. I've had a lot going on the past 6 months.
    I have ARP studs and 17.5mm spacers running 18x10.5 wheels. The tires are 285/30-18s. They do rub slightly on the inside of the aftermarket lateral links but only when pressures are low.
  17. #97
    south-central CT
    What offset? Obviously they are under there... Amazing!
    I tried fitting my STi's 285/645 Continental slicks on 18x10.5" (38ET) on mine and just did not see how it was going to work without body mods.
  18. #98
    Puyallup, WA
    That looks insane! Would love some more angles
  19. #99
    nkw8181's Avatar
    Dallas, TX
    Ithe just looks like any larger then my 265's will rub on the body. How do you avoid this?
    Nolan
