Results 1 to 12 of 12
Thread: Building #911
    Building #911
    I've wanted to build a car for a while. Last December I got home after doing a 9 month deployment to the gulf. And because of the deployment I was able to save the money to get a kit. I spent my free time on deployment researching engines, transmissions, and design ideas. I decided that I wanted to go with a Windsor 302 with an AOD.
    I wrestled around with the thought of getting a create engine and tranny, but when it can down to it I didn't want to just buy a turnkey engine and install it. I wanted to build it. I saw a lot of people using donor cars, so I scoured Craig's list for weeks until I found a car with a good solid engine and transmission. So around Dec 25th I found the car I was looking for, and it was cheap, $700. I'll post some picks of the donor car and the engine that I go out of it once I figure out how to.
    welcome
    Quote Originally Posted by Gunner View Post
    I've wanted to build a car for a while. .
    Enjoy the build and make it one of a kind.
    Thanks for your service.
    DB
    7.0L Hemi33
    #431
    Ol Skool
    upstate NY
    #911, wow, Maybe we hit 1000 this year! Welcome to the Forum.
    I was so excited to get the car in the garage, I forgot to get a pic of it before I started to tear into it. Any way, this the the '88 Thunder Chicken i got my drive train from.
    The engine and transmission looked a little rough...Don't mind my messy garage.
    Was the 88 an IRS or a live axle?
    At least keep the rear calipers from it either way. I ended up with those calipers and some brackets from North so I could put 13" rotors on mine.
    Enjoy the build.
    Dale
    Hemi33
    Welcome home Gunner! It looks like you are off to a good start.
    I think kit number 911 could have some interesting elements to it.
    Best of luck with your progress!
    Aliso Viejo, CA
    I can't believe they are almost up to 1000! Good for FFR. That 33 is a great car.
    Quote Originally Posted by myjones View Post
    The Thunder chicken ended up not have an 8.8 axle. I got my solid axle from a 1997 Mustang GT I found at a pick and pull. I went with the 4 link.
    I got my engine block from the Machine shop the other day. It’s looking great. I decided to paint the block the car's accent color (green). I can’t wait to see what it looks like when I get it together. I’m still a little ways off before I try to start it.
    I also got my axle housing back from the powder coaters. I'm going to have a busy weekend. I did have an issue trying to get the front suspension pieces powder coated. The shop didn't want to try because the ball joints were installed. And when I talked to a machine shop, they said that if they try to press out the ball joint that they would damage them. I thought about just going for enamel but I don't think that it would be very durable. One thing that I though could be interesting was using a product like Herculiner on the front suspension. I won’t be able to all the pieces but if I tape off the bars and flat areas right I think it will ok good and be really durable.
    Looks good Gunner. The front a-arms can be powercoated.. Others have run into the same issue as you. You just have to get all the grease out of the joints. It takes a while but just soak in your favorite degreaser/carb/brake cleaner of choice and compressed air and repeat several times until it's all out. That's all I did and the powder coater had no problems. If not, try another coater. Good luck and keep up the nice work.
    Looking good! Reminds me of my first FFR 33 build I did with a 93 Mustang donor. Came out great, IMO.
    Jan 2015
    St Catharines Ontario Canada
    I had the same issue with the front control arms. My powder coater did not want to do them. I cleaned them with paint thinner and I used brake cleaner after. I had no problem after that.
