Thread: Wild Butch 33HR
    Senior Member clays123's Avatar
    Wild Butch 33HR
    Took delivery of my 33HR 3/18 and started the build.
    2015 Coyote, TKO600, 8.8 Rearend, Power steering, Power brakes, Soft Top, etc.
    Does anyone know if there will be any fitment issues with the Whitby power brakes? We know the Coyote engine takes up a lot of space under the hood. Any other suggestion for power brakes?
    Thanks for the ideas.
    Clay
    Jan 2016
    I was wondering the same thing about power brakes, I too am using a coyote engine and was wondering if this electro power brakes system would work. http://www.abspowerbrake.com/maincatalog_frameset.html
    Supposedly it can be mounted under the dash or other location. Could this be us coyote guys solution? Has any one used it?
    Quote Originally Posted by BigB View Post
    Great idea. I'd like to hear what the experts think.
    Jan 2016
    Any experience would be helpful thanks.
    Aug 2011
    Midland, Texas
    Mine work great without power. Don't have the coyote though, but do use the cobra size rotors and pads from brake motive!
    Check out Kraftee's 33 thread he install the P/B on his. His photos may help you out. Though the Coyote is large.
    http://thefactoryfiveforum.com/showt...s-33-Build-583
    Jan 2015
    St Catharines Ontario Canada
    I stop on a dime and give a nickel change. Remember the car is only 2200 pounds. Before you put the body on adjust the balancer on the master cylinder.
    http://thefactoryfiveforum.com/showt...2-Dave-s-build
