Page 3 of 3 FirstFirst 123
Results 81 to 95 of 95
Thread: THE K-tuned shifter thread
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    That is correct.
    QC, Canada
    Should have posted here I guess since it's K-Tuned related.
    Wayne what's your experienced opinion on this?
    K-Tuned shifter loose?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Kirkland, WA
    OK, I can't seem to get the shifter to shift, I have tried adjusting the damn thing many different times and ways, it seems to move the shifting shaft in/out ok (3 positions) but not side to side. I'm hoping this is not a transmission issue ... Thoughts ???? Getting very frustrated
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Leesburg, VA
    Have you tried unhooking the linkage from the trans, putting a screw driver into the selector shaft and seeing it it will shift, move side to side? That should tell you if there are issues inside the trans.
    QC, Canada
    Yes try to shift it at the gearbox first.
    Kirkland, WA
    Yes, but that was a while ago, I guess I can try that again, but I assume that the shaft all the way in is 1st/2nd and to the left is 1st, right is 2nd ? and 3rd/4th is in the middle and left is 3rd, right is 4th and all the way out is 5th and reverse, left is 5th, right is reverse ?
    Tony Nadalin
  7. #87
    Leesburg, VA
    Looking at trans from the back: Left rotation is counter clockwise, Right rotation is clockwise
    Left In: 1st
    Left Out: 2nd
    Middle In: 3rd
    Middle Out: 4th
    Right In: 5th
    Right Out: R
  8. #88
    Administrator
    Enterprise Alabama
    And the Subrau 5 speed isn't known for it's buttery feel...
  9. #89
    Kirkland, WA
    Left In: 1st
    Left Out: 2nd
    Middle In: 3rd
    Middle Out: 4th
    Right In: 5th
    Right Out: R
    This seems odd as moving shifter left and right moves shaft in/out so moving from 1st to 2nd means moving shifter left/right
    Tony Nadalin
  10. #90
    Leesburg, VA
    You may have your cables mixed up b/w the shifter and linkage. Moving the shifter left/right should equate to rotating the selector arm counter-clockwise/clockwise.
  11. #91
    Kirkland, WA
    hmmm, that may do it, will verify tonight
    Tony Nadalin
  12. #92
    Kirkland, WA
    Yep that was it, seems to now shift into gears, now need to adjust, thanks !
    Tony Nadalin
  13. #93
    Senior Member metros's Avatar
    NoVA
    You're not the only one that reversed those at first
    Glad it was an easy fix.
  14. #94
    Senior Member prematureapex's Avatar
    N/M: Questions answered.
  15. #95
    Edit, thank you
