Well, I've been able to grab bits of time here and there, so time for an update.
I worked on my wiper over the last few weeks, starting with the set up that Lumpyguy used.
Mine sits a bit lower for some reason, but I have full sweep, and I can use the hood as is without cutting the fiberglass. I may need to take a little off the fiberglass return, but not cut into the hood.
I ended up with a 5 1/8 in arm from the motor to the wiper pivot to get full sweep. I used the longest wiper from the standard 2002 WRX.
anyone wants other measurements, just contact me.
