Man, it seems the more I read threads and forums, the more questions I have.
This hour's question: After reading numerous threads about the UCA and UBJ, I noticed on mine that the bracket/mount that holds the upper ball joint is the same on both sides (identical brackets), that is it's not a symmetrical Left and Right set of brackets/mounts. (The welded lug is on the Left side of the bracket on both, so that it ends up on the forward side for the left UCA, and on the rear side for the Right.) Is this correct? It seems a little out of place on the right side, but looks a bit more correct on the left side. I don't think I can turn one upside down, because then the ball joint pin would not point "outward".
Any input? Thanks.
