Thanks Thanks:  2
Likes Likes:  6
Results 1 to 40 of 79
Thread: New Electric Power steering kit for the roadster- Pricing updates
    Aliso Viejo, CA
    UPDATE FOR THIS SPRING
    As I continue to work with my EPS unit provider, we've had to make some adjustments here from the home base in California. Taxes, Liability, etc have caused us to increase the pricing on the kit to $699 Shipped Starting May 1st. SO, if you're at home during this crazy time, and are looking to add EPS, the price will remain the same $650 until May 1st. Please go to https://www.epowersteering.com/purch...factoryfivemk4 and enter the coupon code "33Machine" to receive the discount.
    As always, you get a full year warranty, free shipping, and continued support for installation.
    Hey gang,
    I've done some engineering work and decided to offer an electric power steering kit for the small block Roadster MK3 and MK4 with small block motors. Sorry but it will not fit with the big blocks or coyotes.
    What sets this unit apart from other power steering is that it's adjustable via potentiometer knob in the cockpit. You can dial up the assist for around town and autocross, or turn it completely off for the freeway and road course.
    Install- It will require you to cut the current steering shaft and have the splined couplers welded on. But the welding is not a big job. Just take it to a shop. The custom bracket can be fitted and then welded, and then bolted or welded onto the frame. It will come raw so you can finish how you like after drilling or welding. Location is in front of the headers and not close to the firewall for three reasons- Heat, ease of installation, and space. I've got it installed on the 289 and it's just fantastic. I've tested with power rack from Autozone and the stock Uni-steer rack that comes with the kit. Both work great.
    Pricing is $650 shipped anywhere in the US for the entire kit.
    If you're thinking, "well I could go to the junkyard and get a used one much cheaper, well yes: there is always that, however like most things, getting used gear gets us on the road cheaper but we end up paying for it sooner or later. Like rear ends, transmissions, engines, .... This includes everything you need to get it right the first time!
    ***Currently only available for the MK3 and MK4 with small block motors.*** .
    Here's what comes with the kit:
    Rebuilt EPS Unit- 1 year warranty with customer support
    Custom water jetted adjustable mounting bracket
    Separate ECU
    Two weld on couplers
    Input Shaft Modification EPS Controller
    Adjustment Knob
    2 Electric Plugs
    Block-off Plate
    50/60 Amp Fuse and Fuse Holder
    Dust Boot
    Instructions
    Please just email me directly at [email protected] if you have any questions.
  2. Likes Donkeyteeth liked this post
    I'm about to finally hit the Go-Kart stage. Will keep your kit in mind if I'm not happy with the manual set-up.
    I too have a messed up shoulder and it has finally gotten back to about 85-90%.
    Also, how do you like your Gilmer Style accessory belt system?
    Eric-
    Very nice upgrade Sir! Nice clean installation too. I think it will make it easy for a whole lot of folks to make the switch to power steering. Well done!
    Very nice. I did the exact same thing a while back to my Type 65.
    Milton,DE
    Looks good. Nice job!
    Olli
    Aliso Viejo, CA
    Gilmer works great! No problems thus far. When I researched taking my power steering rack live with the pump, belts, hoses, resevoir, etc, it was just too much. So I went e-steering.
    Lost Wages, Nevada
    Erik,
    Is there any concern about the unit being so close to the exhaust system - and - will it clear 4-into-4's?
    Doc
    Kearney Nebraska
    Nice work! Does this let you adjust your alignment to the power steering castor specs?
  10. #9
    Aliso Viejo, CA
    Big Blocker. Should be no issues on the clearance. Would you consider being a beta for the 4 into 1 for me?
    Yama-bro, yes, you can stretch the caster out as much as you want. I've got mine at 6 degress right now and I'm probably going to 8 or 9 degrees just to get more variance. I put about 200 miles on the car today and had a blast with it. I let a friend test drive it and he loved it vs the non power. I parallel parked like three times one armed. It's just a different car.
  11. #10
    Lost Wages, Nevada
    Erik,
    Although I would be honored to be your test bed for the EPAS system, I have a "custom" set of 4-into-4's (mid pipe back-to-back collectors) and V-band clamps - and - I'm a MKII with the early steering shaft coming out of the DS footbox on the engine side.
    But, that being said, I am really thinking about doing some of my own R & D to see if it will fit under the dash after the pillow block but before the firewall. I'm gunna have to move a bunch of stuff to accomplish that but the effort just might be absolutely rewarding. I'm on a 18:1 Flaming River rack now so effort isn't too much of an issue with +2-1/2° caster and 275x40x17 Nitto's.
    I will be following your progress though . . .
    Doc
  12. #11
    Electric Power Steering
    Your power steering setup looks great.
    How can a buy a kit?
  13. #12
    Aliso Viejo, CA
    Updates to the kit: I've decided to go with two u-joints instead of the couplers so the bracket will have more play to be mounted. What I've found is that out of four cars, each car was different in relation to the the rack input and the firewall bearing that holds the steering shaft. Being able to move the bracket with u-joints is a huge advantage. This one we put into John Tongish's track car which still had the AC bracket. It fits great.
  14. #13
    May 2016
    Nice
  15. #14
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    do you think it might fit in a Mark I? I'm on my 3 or 4 power steering pump - they gradually end up buzzing over time and I suppose after some "limited" use
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
  16. #15
    Aliso Viejo, CA
    The unit would probably fit but I have yet to have a test mule to make the bracket for it. I need to take a look at one of my friends cars out here to see what I need to do. I'll post it up here as soon as I do.
  17. #16
    Nov 2016
    St Louis, MO
    Wow... That's bad ***. I'm getting ready to order and haven't yet, in part because I am still trying to decide on specific set up. This looks like exactly what I'm looking for, the best of both worlds. Having power when you want it and none when you don't. Did you "hide" the potentiometer knob? Do you have any pictures of where you installed it in the cockpit?
    Thanks!!
    Juan
  18. #17
    Aliso Viejo, CA
    Hey Juan, I installed the knob facing down via the horizontal Break in the dash aluminum straight down from the steering column. It's barely visible behind the steering wheel. Does that make sense?
  19. #18
    North Hatley,Quebec,Can.
    Love that,nice compact install,super winter project for me ,on my MK4.Will get back to you.
    Hatley
  20. #19
    Lost Wages, Nevada
    In response to Ralph's post#14, the original YouTube video was an install on a MK I, so the answer of it fitting is; yes, it will.
    I am seriously working on getting this into my MK II with custom 4-into-4 headers. I'm looking into using another unit, [maybe] from a Toyota Prius (that doesn't need the controller from the EBay guy), and see if it will fit under the MK II dash (with some obvious mods to the pillow block location). If that turns out to be next-to-impossible, the Saturn unit is my next best choice.
    As a side note - under the dash sounds really slick but, should it ever need servicing, I'm going to be cussing at myself for ever thinking that was a good location . . .
    Doc
  21. #20
    Master Builder
    Long Island, NY
    Nice and neat , I see it does clear the 4x4 headers.
    Kenny
  22. #21
    Raleigh NC, OIB NC
    Has the system been installed on a COYOTE based car yet?
    Kevin
    MKIV #8234
  23. #22
    Aliso Viejo, CA
    It has not. I'll get to work on that and see what I find out.
  24. #23
    Jun 2014
    Hey guys:
    I was one of the beta testers for the Elec power steering and i have to say this is a really good p/s system. Once Eric got the bugs worked out by the use of two u-joints its great. Installing this was not difficult at all. What i found right off the bat was that it took away 80% of that annoying bump steer you get on the hwy. It made the cruise down the fwy must less effort and twitchy. It also made it so you can really slam it around tight corners and not wear our your forearms. And parking-well thats a no brainer!! i love it and look forward to doing the autocross coming up at qualcomm stadium.
  25. #24
    Very interesting. So this eliminates the need for a power steering pump, belts and pulleys. Allows use of a standard 15:1 manual steering rack? Instead of an "infinitely adjustable" potentiometer, would it work with a potentiometer with detents? I like fixed positions a lot more than a more fluid knob that I'm likely to bump and lose position.
  26. #25
    Aliso Viejo, CA
    Sure does. I can look into the potentiometer for ya. in other news, based on the feedback, I'm going to change the bracket a bit so we can stick to the couplers and not use U-Joints.
  27. #26
    Feb 2017
    MN
    Any news on using this on a 5.0 coyote car?
  28. #27
    Aliso Viejo, CA
    No, sorry. I just don't have access to that setup to get it mocked up and make the bracket.
  29. #28
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    Can this kit be used on a gen2 coupe?
  30. #29
    Aliso Viejo, CA
    Not sure. Haven't tried it. From what I remember this chassis is totally different right?
  31. #30
    Senior Member 42Bfast's Avatar
    Feb 2017
    Pensacola
    Quote Originally Posted by ehansen007 View Post
    Echo the desire to see this for the Coyote install!
  32. Likes toadster liked this post
  33. #31
    Feb 2017
    Coyote here also
  34. Likes toadster liked this post
  35. #32
    Feb 2017
    MN
    PM sent
  36. #33
    Only issue with the electric assist system is that the controller is subject to Heat.
    When the controller gets hot from either location of from heavy use (track/autocross) the electric assist does not assist.
    We have used the electric assist in endurance racing for over 3 yrs. Great system as long as you keep the controller cool.
    Good luck next to headers....
  37. #34
    Aliso Viejo, CA
    Quote Originally Posted by turbodon View Post
    Yeah that's a good point. I plan on putting a heat sink on there. Or relocating.
  38. #35
    RR20AC's Avatar
    Puyallup/WA
    On my build, I used the unisteer steering and modified the wiring to place the controller in the foot box along with the variable assist module. The motor is protected by a shield with lizard skin heat treatment toward the electric motor. I made sure I can remove the controls later. It is really tight though.
  39. #36
    NORTH CENTRAL CT
    The gen2 is similar to the roadster just not sure how similar.
  40. #37
    Aliso Viejo, CA
    Ok, finally got some time to work on the bracket. More details to come. Hoping to get the design modified and water jetted this week.
  41. #38
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    I sent you a IM to see about getting a kit to install on my Ol' Mark I
    Ralph Button
  42. #39
    Aliso Viejo, CA
    Well, we can still get you the unit and you'd just have to fab a bracket for it. Although I think I'd like someone with a few more miles on their car to be the beta.
  43. #40
    How do we order?
