![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
0
So i need to clarify some of the data that i posted. While trying to provide data sooner than later, i did not fully understand the Anemometer and air flow as it relates to this test. The meter had a preset area of 160 in^2 (1.11 SF), of which all of the data that i posted in the previous post reflects.
Below is a table showing the data based on actual surface area of the opening for the scoop as well as 3" and 4" duct opening (which is what an inner scoop would more than likely have. The X axis would be the MPH and the Y axis being the CFM. Ive attached the data used for the graph to show more data points.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
