Thanks Thanks:  8
Likes Likes:  31
Page 20 of 26 FirstFirst ... 101819202122 ... LastLast
Results 761 to 800 of 1012
Thread: Frank's 818R build
  1. #761
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Oh no!!! Sorry to hear that frank. That's a real bummer. It's pretty easy to pull the transmission apart, if you want to see what is broken. It will be obvious.
    You mainly have three options:
    1. Buy another used 5-speed, maybe a later model one like 08-up, and cross your fingers it doesn't happen again
    2. Get a set of PPG gears and have your transmission rebuilt with them installed
    3. Get a 6-speed
    Keep us posted on what you end up finding and doing.
  2. #762
    Mar 2014
    Oakley, CA
    Sorry to hear of the trans problems. I'm surprised, looking at your dyno chart, that it didn't hold up. Was it old? How many miles on it?
    I had Andrewtech Automotive in DC rebuild my 6-speed. It was a 2005 so I had to use the adapter from Possum Motorsports, too. All in it was surprisingly expensive, but hopefully it's an investment in making sure I don't experience what you just did.
  3. #763
    Sgt.Gator's Avatar
    Bend, Oregon
    3. Get a 6-speed
    There's a 4th option. The 5 speed with an LSD and Moore Performance BlastPlates. So far all the guys that I'm aware of using the blast plates have yet to break a 5 speed. it's worth a Google search to read about them. Maybe it's a placebo, maybe not.
    Owner: Colonel Red Racing
    818R ICSCC SPM
  4. #764
    Clovis, Ca
    Legacy GT trans..... I never had an issue, and I was not very nice to it.
    Thanks- Chad
  5. #765
    Sgt.Gator's Avatar
    Bend, Oregon
    +1 on the LGT tranny. That is the base to start with on your rebuild. You can get them fairly cheap at a wrecking yard or on the forums from guys who've done a 6 speed swap into their LGTs.
    818R ICSCC SPM
  6. #766
    Feb 2014
    Asheville, NC
    Thanks for all the advice, all. Splitting the case tonight to see what it looks like in there. LGT trans sounds like the best bang per buck. I wasn't nice to this trans but it just was a WRX one (07, so not the weakest but also not the strongest). I think part of the solution is a behavioral change (less burnouts).
    Frank - Build thread
  7. #767
    Hey, hello? Not "all", don't thank me for my stupid advice, come on. lollll
    This would also reduce fun, but in the end if the car is dead it's the worst fun you can get anyway.
    And again I think you've proven that the trans seem like a weak point for this build, at least the non-upgraded Impreza ones.
    Do you have an LGT in sight already?
  8. #768
    Feb 2014
    Asheville, NC
    Nope. After buying another bike (and still haven't sold the old one), I'm pretty sure my bank account doesn't support me getting another transmission yet. I think LGT is the way I'll go, the more I think about it. Hopefully it's stronger over my 07 WRX one.
  9. #769
    I hope for you it's stronger than the 07 WRX, otherwise it'll break again and put another hole in your bank account.
  10. #770
    Feb 2014
    Asheville, NC
    So, I cracked the trans open. Found that the pinion/ring gear are destroyed. Luckily, they're fairly cheap and nothing else seems to be damaged. Now the question is, besides doing less burnouts in it...how can I avoid this happening in the future?
    I would imagine that someone makes a stronger ring pinion out there, no? Also, this is the time for a new diff, eh?
  11. #771
    Clovis, Ca
    No Burnouts, change fluid more often. I'm a firm believer in Swepco 201. If it happens again, you will benefit from a transmission cooler/pump setup.
    Thanks- Chad
  12. #772
    south-central CT
    And, yes, a diff. With my AWD STi, I was told that I could gain two seconds a lap (a second a minute) with racing diffs in my STi. I've yet to prove it because of engine issues, but I'll know soon. I went with OS Giken.
  13. #773
    Feb 2014
    Asheville, NC
    Fluid was fairly new (2 track days on it?), and was Motul 300. I will be trying other fluids next time, I think. Thanks for the advice, Chad.
    I've heard a diff is good for 1-2 seconds on a full track in the 818. I believe it. I definitely have a moment of lower delivered power coming out of harder turns.
  14. #774
    Clovis, Ca
    If you only had 2 track days on the fluid- Stay away from burn-outs. Motul is good also I hear, I have never used it. I used Swepco 201 in the 818R and the 911's forever.
    Thanks- Chad
  15. #775
    Feb 2014
    Asheville, NC
    So, not directly related to the 818, but it will become relevant. I took my WRX to the track this Friday. Had two problems- I was blowing some smoke (maybe turbo seals or head gaskets?) and I was SO BORED. The 818 has ruined me. So, the WRX is going away and a brand new pickup truck is coming in its place. This is slowing down my 818 fixing budget/timeline, but it'll be a lot easier to tow this thing around with a proper tow rig than with my early 90's, 6 cylinder truck. Can't wait to go more than 30mph up the hills on the way to the track
  16. #776
    Hindsight's Avatar
    Atlanta
    Nice Frank! I have been eyeing a tow vehicle as well. My VW Passat TDI is getting bought back by VW due to the Diesel scandal, and I've been researching trucks to replace it. I don't have a daily commute now so gas mileage isn't a huge concern. What kind of trucks have been you been looking at? Will you go open or closed trailer? I'd much rather have open for weight/cost but with the open-top 818, closed makes a lot more sense.
  17. #777
    Mechie3's Avatar
    The first time I drove an F500 I almost instantly lost all desire to autocross a full sized/non full race car again. It actually had the benefit of I lost interest in my WRX (now my 818 donor) and my street cars are no longer super uncomfortable racers with $16k in mods. Put all that money into my 818 instead.
    Zero Decibel Motorsports
  18. #778
    Feb 2014
    Asheville, NC
    I have an open deck trailer. 3 reasons I want to upgrade. First and foremost, loading/unloading is AWFUL on my trailer. Far and away the worst part of my tow rig, including doing 30 (sometimes less) up hills in a 55 mph zone. Second, sleeping in an enclosed would be nicer than sleeping in the back of the pickup like I do now(though it's a lot nicer than a tent). Third, being able to lock up the car/tools would be nice.
    I'm getting a 2016 F-150 with a V8, a 3.73 rear, and some creature comforts. Combo of my favorite current truck and work discount (we supply them with metal).
    Yup, that happened to me the second I went back to a regular car after driving the 818. Best part is that the mods for the 818 are cheaper/as cheap as the WRX, and they make me way happier. So, boring street "car" (truck) and fun race car (and race bike). 100% understand why Formula drivers have Camrys and stuff.
  19. #779
    Feb 2014
    Asheville, NC
    Started my install of the side scoops. They look awesome, Kurk!
    Ew, gross stains on the old FFR mesh:
    Not bad progress for an hour or two. Gonna make brackets at work this week, I hope.
    Not cutting out the driver side until I choose and obtain a core for an oil cooler. The passenger side core is for an AWIC, of course.
  20. #780
    Hindsight's Avatar
    Atlanta
    Cool, I have been looking at F150s as well. I have never bought or owned a truck, and I am still having a hard time understanding why a reasonably featured pickup truck costs $40,000 to $60,000. It's nuts! You can get a really nice Mercedes, Audi, or BMW for that kind of money!! Of course, those won't tow a trailer.....
    Any reason you are going with a V8 instead of an ecoboost? If I went new, I'd probably get the ecoboost, but if I go used, will probably go V8 instead.
  21. #781
    Mar 2014
    Oakley, CA
    Just to throw some thought about engine choice out there: I'm towing one of FFR's new 24' trailers with, of all things, an F150 Raptor. The Raptor does great IF, and ONLY IF, you get a weight distribution hitch. The trailer weighs about 4k empty. The Raptor with the tow package (10k Class 4 hitch, trailer brake controller, tow/haul mode, trans cooler) is basically the same in powertrain and brakes as an F250 with the same engine (6.2L V8). The Raptor's soft off-road suspension is the only drawback and is why the weight distribution hitch is necessary. I think it's worth it to spend some bucks on a good tow vehicle. You'll spend some hours in it, and it's nice to be comfortable and not have to worry about being overloaded. In the Ford line, a well-equipped F250 with pretty much any of their engine options is plenty to tow this car in an enclosed trailer. Can't speak to the Ecoboost, but the specs on it suggest it should work fine.
  22. #782
    Man you are a true racer, you wreck every thing you drive. Just don't wreck those 2 pick-ups and get that 818 fixed! Completely fixed for a better life!
    I can't believe how small your FFR side openings were. Really, that is so tiny.
  23. #783
    Puyallup, WA
    Glad you like the fitment.
    I will be doing something similar to your side mount IC.
  24. #784
    Member jcpresto's Avatar
    Hindsight,
    What are you wanting to pull? My Audi Q7 pulls 7k lbs without an issue.
  25. #785
    Edmonton, Alberta
    +1 for an ecoboost, I'm very happy with mine.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  26. #786
    Sgt.Gator's Avatar
    Bend, Oregon
    You are starting the progression!
    Ratty used open trailer pulled by SUV or old pickup. > Nicer open trailer pulled by nicer /heavy duty SUV or light duty pickup. (F150) > Enclosed trailer about 18-20-22ft>After a year of jamming too much stuff in too small a trailer...trailer envy hits and you buy a 26' tag or even a 30+' fifth wheel. Realize you need more powerful pickup, buy a Ram 3500 /Ford 350/Chevy 3500 Turbo Diesel with 800ft lbs of TQ. Finally happiness!
    You might as well save a bunch of $$$ and go straight to the end game.
    818R ICSCC SPM
  27. #787
    Feb 2014
    Asheville, NC
    Yes, but those can't tow You do get a lot of vehicle with a $40K truck right now, in all honesty (the comfort is amazing, the power, etc.) but it still pains me to spend more on my truck than my 818. V8 for 3 reasons:
    -reliability: it's a very tried and true engine and I have friends at Borg Warner who say their cam phasors for the 3.5Ecoboost are prone to failure.
    -V8 rumble (self explanatory)
    -I found the almost-exact truck I want in-transit to a dealer that I'm grabbing instead of ordering one, and it has a V8. If I ordered one, it'd be close.
    Quote Originally Posted by Zach34 View Post
    I'm sure mine will also be fine towing, as it's rated for 11K and change and if my current truck is any example, you can always tow more than you are rated for Towing with a Raptor is badass, though.
    So tiny! They didn't really have much to cool I guess, not directly anyway. And yes, recently it's been EVERYTHING. Gonna try not to break my pickup trucks.
    I think this is the "best" spot for an IC if it can work heat-wise. Drag is more desirable than lift from a top scoop
    Quote Originally Posted by jcpresto View Post
    Hindsight,
    I'm sure any of the large SUVs can tow nicely, and do double-duty for family vehicles if you want them. Since it's just me, truck is where it's at
    I'm skipping to the end trailer wise. 26' is my minimum trailer size. I think a nice 26' can be 3k-4k pounds with a few cabinets and stuff in it. That, my 818, a bunch of tools, easily still under 11K and change tow rating, not to mention I have a bed to put some tools and such in (and motorcycles).
    I did 15K miles in my '93 F-150 with no AC, a bench seat, enough power to slow me down to 30mph going up hills, and no creature comforts (AM/FM radio leaves a lot to be desired). I am so excited to have an upgrade here.
  28. #788
    Do you have more info about the components of your side mounted AWIC? I like the way it does away with need to mount anything up front. What heat exchanger are you using after turbo/on top of engine?
  29. #789
    Hindsight's Avatar
    Atlanta
    Good point about the reliability of the V8. The ecoboost gets better mileage but the reliability factor needs to be considered as well and the V8 has been around forever and has been very refined.
  30. #790
    Feb 2014
    Asheville, NC
    Quote Originally Posted by tmoretta View Post
    I do have plans! I will take pics of my proposed solution and upload them next time I get some time in the garage
    plus the V8 rumble! Same engine as the Boss 302 except a camshaft. After my Subaru's reliability compared to my Ford's, I'm done taking risks on the street-going vehicle
  31. #791
    Clovis, Ca
    I have a 2013 F150 Ecoboost Lariat 2x4. I'm not sure if I'll get the Ecoboost 3.5L in the future, I may go V8. Towing my trailer I get ~8 MPG..... ~7500 pounds of weight. The Ecoboost MPG is good at the beginning, now with 80K miles it sucks frankly. I'm lucky to get 17mpg highway unloaded......
    Towing with a Raptor limits the capacity due to the suspension. My F150 has 11,000 towing capacity.
    The 2011+ Raptor super crew has a towing capacity of 8,000 pounds. The 2011+ Raptor super cab has a towing capacity of 6,000 pounds.
    Thanks- Chad
  32. #792
    Did you look at the Ram eco diesel? 8000lbs towing and they sell for pretty reasonable prices out here.
  33. #793
    sooooo, I'm guessing the 2017 F150 3.5 ecoboost with 10 speed transmission is out of the question
    (Because more has to be better)
  34. #794
    +10 V8 rumble
  35. #795
    Sgt.Gator's Avatar
    Bend, Oregon
    I towed an enclosed trailer with a Ram 1500 5.7L V8 Hemi, 400 HP/400TQ for a couple of years. It was ok. Now I have a Ram 3500 Cummins Turbo Diesel. 800 Lbft TQ. The Cummins is awesome. Super Reliable. Once you tow with a heavy frame pickup and a monster 6 cyl Cummins turbo diesel you'll never go back.
    818R ICSCC SPM
  36. #796
    south-central CT
    You guys are giving me truck envy. In the New England area I struggle on a few steep spots (down to 45mph) but I normally get by fine with my 2008 Dodge Dakota V6, with roll-up windows, when I tow my 3K lb. STi on a 13' tandem-axle Featherlite. I too looked at new trucks and SMH! Also, it was a slippery slope of money when it came to power and accessories for a new truck. I've managed for years backing up under my trailer tongue without a computerized camera. I'd rather put the money into the go-fast stuff. I could not justify it when I have little use for one for anything else.
  37. #797
    Feb 2014
    Asheville, NC
    So, I bought a Qauife LSD and a new ring/pinion (heat treated this time!) and some bearings for the trans. Gonna have it rebuilt by my tuner (Taylor at Moon Performance) and will hopefully be able to do a few street miles to test it this year before the wintery hell hits. Pretty excited for the LSD!
  38. #798
    Cool, this is been taken care of now. You cannot rebuild it yourself? I wouldn't either on mine, I'm not experienced enough on this component.
    Next step: fixing the body.
  39. #799
    Feb 2014
    Asheville, NC
    high on my to do list
  40. #800
    Hindsight's Avatar
    Atlanta
    Nice, I love my Quaife. Puts the power down very nicely on turn exits. How much does a heat treated R&P run? Any torque strength estimates on it?
