Results 1 to 17 of 17
Thread: Heat in the footwells
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Now that we have about 450 miles on our 818 we have a little problem to solve. The wives are complaining that their lower legs and feet are getting too hot. Since the hot water tube runs up the passenger side, the passenger side gets quite a bit warmer than the driver side. Last night we measured about 110 degrees around the passenger side dead pedal with both dynamat and carpet in the car.
    Does anyone have any thoughts on either further insulating that area of the footwell or getting some air movement in there so the air in the footwell doesn't get so warm?
    Larry
    Jan 2012
    You could make a cutout where the fender liner meets the side sail and insert a mesh grill to keep rocks out. I can take a picture of the car thats at iWire right now. It would solve your problem but only if your willing to let water into your side sail if you hit puddles or rain. There would be airflow over the pipes going down the length of the car. It wouldn't cool the dead pedal but would help a bit.
    Michael and I ride in the passenger side all the time. Never noticed any heat in the foot well area. I have a hard time believing that heat is coming through the dynamat and carpet.
    Is it possible that hot air from the radiator is coming over the front firewall.?
    The engine bay is higher pressure than the cockpit. So any leaks in the side sails to cockpit is hot air. The side sails should be blocked off at the rear firewall.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I'll do more checking but I'm pretty sure the heat is coming from the dead pedal area. When my wife put her purse and jacket on the floor in that area she was more comfortable and when we stopped her purse was warm. IR thermometer said dead pedal was 110 and the temp dropped off pretty quickly when moved away from there.
    Larry
    Do you know if your tube in that specific area is touching against the dead pedal's alu panel or is it away slightly?
    Senior Member Blwalker105's Avatar
    Take a look at a Thermo-Tec 14500 Cool-Air Tube Heat Shield. Might solve your problem for about $60.
    Senior Member AZPete's Avatar
    You wrote, "the wives are complaining" so I must ask how many wives you have. My only wife makes sarcastic comments about the time and money I'm spending on my 818 so I can only imagine multiples of that from all your wives. Heat is the least of your problems.
    That really is one of the funniest reply I've seen. There is actually no problem with heat in the dead pedal.
    Feb 2014
    Asheville, NC
    haha it really is an excellent reply.
    K3LAG-- I echo what Bob said. I've ridden shotgun and haven't heard complaints or felt that myself. Are you sure the epicenter of the heat is the dead pedal/coolant lines?
    Frank - Build thread
    Drive when it's cooler and the heat will be welcome😉
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I figured someone would make a crack about the 'wives' statement. My best friend Dave and I built the car together and both of our wives have complained. I could have said 'Our wives' but then you all wouldn't have something to get a chuckle out of.
    I'll have to take a closer look to see if the tube is touching the aluminum or not. I don't remember it touching but it's worth checking.
    Keep the ideas coming but I won't get a chance to look at it for at least a few days.
    Larry
    Freeport, ME
    Quote Originally Posted by DMC7492 View Post
    Drive when it's cooler and the heat will be welcome��
    I agree, it's a feature. I'd add a layer of insulation in the area for when it is hot and simply remove it when you want some heat in the area. Mine has some heat there but it isn't much due to my 1/8 inch foam covered with high grade vinyl.
    Dan
    Is it possible to add a vent for fresh air to the foot-wells? This would increase the pressure in the **** pit and provide some cooling on hot days.
    I would check the panel under the dash where it blocks off up to the windshield frame. Before I install that and sealed it off I would get a ton of heat coming off the radiator. It was so much I thought about installing a slide vent to get some warmth in the cabin when it was cooler outside. Also make sure you installed the edge bulb gasket on that panel to seal it off. Just a thought as to why you may be getting the heat. I also have not noticed any heat coming through foot well from the coolant tubs.
    San Diego Ca 92106
    Yes, I'm planning on it. I'm using a system used by the Cobra crowd using parts based on a former vendor Cobra Earl.
    https://www.google.com/search?q=inst..._AUIBigC&dpr=1
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I haven't had a chance to test drive it yet, but we did find a few unsealed spots in the front firewall. Supposed to get some nice weather this week so I should get a chance to get it out for a bit.
    Larry
    Feb 2017
    I have not tested for this problem but I did use the foam from the donor car and packed the dead pedal area. Before I installed the dead pedals I thought that this would be a potential problem. Will post result soon, started body work this week. Gocarted down the street once.
    Charlie
