Results 1 to 40 of 55
Thread: Gauge Cluster Surround/Gauge Mount: Zero Decibel Motorsports
    Mechie3's Avatar
    Indianapolis
    While looking for a way to mount gauges I decided to make an entire surround for the OEM gauge cluster that also had room for four gauges. This way my gauges are all mounted uniformly and look like they were intended to be there.
    It is bare aluminum, but can be polished, painted, or powdercoated (by the end user) to give more contrast if desired. Flush mount pem studs hold it in place so you don't see hardware if it's painted (unpainted you can see the difference in color of the back of the stud). Comes with the studs pressed in.
    CAD rendering is below. Gauges on left are prosport premium, top right is regular prosport, bottom right is an AEM guage. Outer bezel of the AEM gauge is 2.36" and is about the maximum. Prosport are 2.27" and have a little more clearance. Anything bigger than 2.36" will likely have interference with the gauge above it unless that one is smaller. Gauges are 2.44" center to center so you can measure your gauges if you have questions about whether they'll fit or not.
    Pricing:
    5 People: $55
    10 People: $40
    15 People: $35
    20+ People: $30
    1: Dodgy Tim: Cutouts
    2: Joseph: Cutouts
    3: Wirenut: plain
    4: SnyderJD: Cutouts
    5: BlWalker: Plain
    6: Fastzrex: Cutouts
    Pricing is the same for one with qty-4, 52mm cutouts or for a panel with no cutouts.
    Check out my new website!
    Kirkland, WA
    Is this designed to fit over the stock FFR plastic dash, looks like some cutting would be required ?
    Tony Nadalin
    2022 SOVREN Championship
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    Mechie3's Avatar
    Indianapolis
    I mounts right onto the dash. You'd have to drill holes for mounting and cut out four 52mm holes for gauges to pass through. Its more a decorative piece than anything.
    Jan 2012
    Why do you always tempt me...
    Edmonton, Alberta
    Looks good, now if only it was carbon fibre and cut out for an AIM dash, lol
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    May 2016
    Or carbon and not cut out at all
    Mar 2015
    Houston, Tx
    Sign me up. Again.
    Mechie3's Avatar
    Indianapolis
    Took pics of the paper mockup this morning. The little winged Zero logo can always be removed. That's there because I'm putting it on mine but I get not everyone would want that.
    I could look at waterjetting carbon fiber blanks. I assume by no cutout people mean no cutout for the gauge cluster AND no cutout for the 52mm gauges?
    Craig, That looks good, but, you have got more important things to do.
    Congrats,
    Mechie3's Avatar
    Indianapolis
    I slept at home last night with a screaming 2 year old. Lol. Took that pic on my way to the hospital after dropping daughter at daycare.
    Nov 2015
    Caledon, Ontario
    Carbon fiber would be a nice option. Cut out for gauge cluster, but blank on 52 mm gauges (supply a paper template)? I would advertise your logo. Would your logo cut out okay on carbon fiber?
    Edmonton, Alberta
    Quote Originally Posted by THE FURNACE View Post
    I would buy exactly that. The template for the gauges is a good idea. I would just ask for the cutout centre section so I can make a matching mount for an AIM dash. Also, maybe think about matching door card inserts.
    818 SRX - #91
    Arrived 01/02/2014
    Dec 2014
    north east ct
    sign me up for one no holes for round gauges thanks brian
    Senior Member DodgyTim's Avatar
    Brisbane, Australia
    Any reason one of these won't fit a right hand drive dash?
    Kirkland, WA
    Quote Originally Posted by DodgyTim View Post
    Holes would be on the wrong side, you would need to flip the car around and drive backwards
    Tony Nadalin
    Senior Member SnyderJD's Avatar
    Jun 2015
    ill take one.
    Brisbane, Australia
    I'll take one in alloy with the gauge holes
    Mechie3's Avatar
    Indianapolis
    Depending on how accurately FFR made the LHD vs the RHD dashes you might need to trim it or more of the dash might show through. We already know FFR handmakes all their molds so there's plenty of room for variability.
    I need to make a change to the template and then I'll quote it with no holes. Been a bit busy lately. New baby was in Nicu for a couple days, then home, now back in Ped's for really high biliruben counts. Haven't been on much lately.
    Brisbane, Australia
    Wish you well with the bub
    Both my sons were in the Nicu for 100+ days each, I know how stressful that can be
    Mechie3's Avatar
    Indianapolis
    First was in NICU for 36 days. This one was there for a day, then out, then back for a day, then home for two, then into the ped's for 2. He's home now and good. Biliruben is an easy fix. Turned out to be an ABO incompatability (wife created antibodies against his blood type during the birth when blood mixed, antibodies from my wife were in the baby breaking down red blood cells).
    I made the change I mentioned. Not sure I like it. In theory I liked having the radii on the small electrical panel and the cluster surround match, but in practice I think it makes the cluster surround look too square. Thoughts?
    Aug 2012
    Long Island
    glad everyone's good.
    looks real good!
    I still feel the small panel needs a little bump up to match the dash curve.
    also my stupid thought... would it be better to make it with 4 centering holes rather than cutouts? then people could just drill as needed through the trim and into the dash, or add indicator lights or switches.
    Aug 2013
    I want one.
    Mechie3's Avatar
    Indianapolis
    More than likely I'd make it blank but provide a printable template to center the holes. That way if you didn't want anything there you wouldn't end up with four pilot holes.
    Senior Member Blwalker105's Avatar
    Sign me up Craig, and I vote for the top one.
    Apr 2015
    Andover, MA
    looks real good!
    The tiny radii dont look like a good match to me, of course everything is relative and most all of your creations look pretty darn good! I like the switch panel swooped up to match the instrument surround.
    -Ben
    Here is another twist on your theme:
    Edmonton, Alberta
    looks real good!
    I really like the bottom one
    818 SRX - #91
    Arrived 01/02/2014
    Mar 2014
    Bottom one Please
    Mechie3's Avatar
    Indianapolis
    looks real good!
    I need to update the electrical panel piece. With where I mounted mine, I'm not sure the uptick on the left edge would go that far towards center. Honstly can't remember. It's been a super quick 6 weeks since the baby was born.
    I sent an email to the shop asking if I need to create new part numbers for blank vs cutout versions. Once I hear back I'll be asking for official "I'm in" votes to start the group buy.
    Thanks everyone.
    Sep 2014
    Craig, really like the layout - I am not going to use the factory WRX gauge cluster and was looking for a good alternative using Speedhut instruments.
    What would it take to create a piece to replace the factory cluster and use a separate Speedo & Tach unit ?
    I dont have access to all the fun CAD stuff, Something for you to kick around in your spare time.
    "E"
    Senior Member mistasherm's Avatar
    East Central PA
    Craig
    Are you planning to offer these pieces as a pair (gauge cluster and electrical panel) or separately? Great work - really like the electrical panel. Glad all is well with the kiddos - we have four at home, never a dull moment.
    Ty
    Mechie3's Avatar
    Indianapolis
    Innkeeper: Do you want a panel blank that sits down inside the cutout where the gauges are, or are you asking for a cluster surround that is fully solid?
    Mistasherm: I'm working with Iwire to create an electrical panel. I have several hours of wiring into mine because of the switches and functions I chose. I wire will have a much easier solution.
    Sep 2014
    Yes, a panel that will replace the factory WRX gauge pod. Using a 4 inch Tach & Speedo, I think with the correct spacing I can place the AFR gauge in there also ( like this = OoO ) add your surround for the other 4 gauges.
    Senior Member fastzrex's Avatar
    Oklahoma City
    Put me on the List
    Love the panel layouts. I prefer the top panel design. Please conact me when you are ready for payment!
    Thanks everyone.
    Mechie3's Avatar
    Indianapolis
    Quote Originally Posted by Innkeepr View Post
    I would just attach a piece of material behind the opening and make cuts where you need them. There's no need to make a piece that matches the cutout perfectly because the excess material will be hidden by the dash itself. After it's installed layout where you want the gauges and make some cuts.
    Sep 2014
    Thanks Craig, I dont have a dash to mock up right now, just trying to figure stuff out. With 1 in college and one starting in another year - I am hoarding parts at an alarming rate ! Stripped the donor, bought an ej207, and still have my MK II in pieces as I added a heater, new seats, fresh air vents, and second roll bar. Thankful for a wife that puts up with my hobby.
    Best wishes,
    "E"
    Mechie3's Avatar
    Indianapolis
    I got quotes back for a blank version (missing the four gauge cutouts). I'll post updates shortly.
    Innkeepr. Chris on facebook has done exactly what you're looking to do. Posted pics a few days ago. Don't remember if it was his personal page or on the 818 builders group page. If you can't find it I'll see if I can share the pics here.
    Mechie3's Avatar
    Indianapolis
    Not posting updates yet. I was reviewing pricing and the blank version was quoted 37% higher than the version with four cutouts. I sent an email asking why. As soon as I get it I'll update pricing (hopefully the blank version goes down and the cutout version doesn't go up). Once pricing is up I'll be taking names for who is in and whether you want a blank version (center cutout + logo only) or a cutout version (center cutout + logo + 4-52mm gauge cutouts).
    Mechie3's Avatar
    Indianapolis
    Pricing updated. If you're interested let me know if you want the version with the cutouts or without the cutouts. Pricing is the same for both.
    Thanks.
    Mechie3's Avatar
    Indianapolis
    If anyone wants these, please post as I'm not using the original "I'll take one" posts since pricing was changed by the shop. Want to make sure people still want them at the new price (think it went up by $5? Don't remember).
    Craig
    Tallahassee, Florida
    I want the one with the cut outs. Tell me how to send the money, PayPal? I am Joseph on the forum.
