OK, so I get it that FF is a quasi-cottage-industry but the interface of the new front end's upper front door, front fender and windshield area is truly a nightmare. Did they really pay someone to create these molds!?! I have spent the better part of the last 5 weeks trying to get these ridiculous parts to fit with the hope of it looking even semi-professional when finished. I thought I had seen the worst with having to cut a giant pie-shaped slice out of the hood to address one fender being 1/2" shorter than the other,
but after fitting both doors, there are HUGE triangular-shaped gaps at the aforementioned interface areas. WTF?!? Did the person making the front fender molds even live in the same zip code as the door and hard top fabricators?
Enough ranting. In an effort to eventually have a finished car, I have come up with a workable solution to these troublesome areas. It may look a little daunting for those uninitiated with fiberglass techniques, but it is more a matter of proper prep-work and materials than anything else. First, an overview: the factory hardtop's front lower A-pillar areas are cut very flat (and poorly) and sit directly above compound-curving upper front door areas and front fenders whose rear edges don't extend far enough rearward. The result is this:
a monstrous void that can only be minimized by painting everything black, standing back 20 feet at dawn or dusk, squinting and hoping everyone pays more attention to your smokey burnouts than your build quality. Gross!!!
I wanted something like this, but was turned off as it looked too Viper-esque
so I decided to strike out on my own and get crazy with it:
