Results 1 to 15 of 15
Thread: Front Splitter - How is it on the track?
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    For those of you running the R model splitter on the track, I'm curious to see how your splitter is holding up on the track. Also, about how much does it weigh?
    I'm trying to decide between making my own out of alumacorr, or buying the FFR one. FFR's is like $650 shipped, or so. I can make one for about $215 in materials out of the alumacorr and feel it would be a little more disposable/replaceable, and plenty strong.
    Thanks!
    QC, Canada
    The splitter weighs almost nothing, maybe say like the rear engine cover or less.
    650 vs 215, that's a huge difference!!! Why are you still questioning which one to get if for 215 it's replaceable and strong?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Hindsight's Avatar
    Atlanta
    The FFR one looks a lot nicer. Alumacorr isn't pretty, but it gets the job done. I'm glad the FFR splitter is light though!
    Senior Member DSR-3's Avatar
    San Jose, CA
    Do factor in repair-ability. Yes, I ran super-low ride height on my car that had a splitter, but it(they) took a beating- kerbs, rocks, other cars the ground, feet, etc... I was never sorry I made them from good 1/4" plywood with a layer of CF (for looks...) over a layer or 2 of s-glass on the top, and a couple layers of glass on the bottom. Layed-up on a sheet of waxed melamine.
    QC, Canada
    Jeff, the old style CF FFR splitter weighs just a little less than the rear engine cover.
    Senior Member Rob T's Avatar
    Woodruff, SC
    I've had 4 days at the track and been over all the rumble strips. Chad had the car out several times before that. The lowest point is about 3 3/4 inches off the pavement. It sticks out in front of the fiberglass about 4". I've even been fully off the track in the dirt, once. No damage. However, I've got a total of 14 feet of ramp to hit the back of my trailer when the deck is 16 inches off the ground. Mine is carbon fiber. Not sure which version. The front splitter is a long way in front of the wheel making the angle of approach really low.
    Hindsight's Avatar
    Atlanta
    Thanks for all the replies. Some good info and ideas here. I like the plywood overlaminated with fiberglass/carbon. I might skip the carbon (to save money) and just paint over the glass with some black paint, if I go that route.
    Thanks again.
    Kirkland, WA
    Thanks again.
    Aluminum weighs less than the laminated plywood
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Edmonton, Alberta
    Whenever I think about a plywood splitter, I'm reminded of Top Gear and when they built one and caught it on fire.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    QC, Canada
    HAHAHAHAHAHAH!!!! Yeah I remember, what is it they haven't done... when Clarkson was there.
    Leesburg, VA
    Too soon
    Feb 2013
    Westminster, MD
    IMO it's a vestigial part. Unless you add bracing and mounting struts it will fail at track speeds.
    Hindsight's Avatar
    Atlanta
    Quote Originally Posted by SixStar View Post
    You don't feel the splitter adds down-force?
    Kirkland, WA
    Mine does, I can feel the aero help much above 80mph, slower I don't
    Tony Nadalin
    Kirkland, WA
    Here is the height of my
    Tony Nadalin
