Results 1 to 5 of 5
Thread: Seat belt options
    Sep 2011
    Seat belt options
    What does the 818C use for seat belts? I'm under the impression it uses the stock donor seat belts. Is there an option for a 5 or 6 point "performance" belts?
    Robert
    Super Moderator
    Ray's Avatar
    La Mesa, California
    You get tired with the Roadster already?
    Ray
    Sep 2011
    Adding to the fleet
    Quote Originally Posted by Ray View Post
    Ray
    Building it with and for a friend. The idea of a roof and some sort of heat is appealing though.
    DFW, Texas
    Quote Originally Posted by Clyde's Keeper View Post
    Robert
    It uses the donor belts (02-07 WRX seat belts). You can easily mount 5 or 6 point harnesses to the tubes. There is also an available harness bar from FFR.
    The seat belts will require special mounting if you want to go 5 or 6 point. Here is how I did it I am sure there are other ways. http://redfogo.com/index.php/seats-harnesses/
