Thread: Electronic E-brake
    Electronic E-brake
    Has anyone else considered or currently running an electronic E-brake setup? Been looking at incorporating one or considering a line lock for the front brakes to use to hold the car.
    This is the one I've been considering: http://www.speedwaymotors.com/E-Stop...Kit,65217.html
    Freeport, ME
    You could do it much cheaper, I bought a linear actuator but ended up doing it the old fashioned way...
    for example http://www.ebay.com/itm/New-Heavy-Du...kAAOSwImRYPH7l
    Dan
    Interesting. I'm interested in tidying up the interior with as few items on the center seat console as possible, as in just the shifter and window controls. After getting used to the push-button E-brake in my wife's Outback, I figured one would be something to look into when I build my C.
    I think something I should have done before yanking the rear hubs out was measure the length of pull on the cables to figure out what length of actuator to get.
    Freeport, ME
    It isn't more than 2 inches max
    Dan
    Baldwinsville, NY
    I just finished mine. I used a 2" actuator. Purchased from the same link shared by RM1SepEx. If you need to shortened the stroke you can by removing the cover and exposing the end switches. I drilled and tapped the end of the actuator to allow a 1/4" threaded rod for easy cable adjustment.
    http://https://photos.google.com/share/AF1QipP6_L9qaBV1l7i3yx8h9XBZnBPP7fRzj1pR21zo12XN5u DIYNJcxE0X8TaC1kQETw/photo/AF1QipMW-VGC0WsgYVR1ayg_R1uzFHu-TqWT6M4Eqfw1?key=bjRmQ1dqSHJHcE5JeGVNaVl3S1FIcm9yR mpwOFVB
    http://https://photos.google.com/share/AF1QipP6_L9qaBV1l7i3yx8h9XBZnBPP7fRzj1pR21zo12XN5u DIYNJcxE0X8TaC1kQETw/photo/AF1QipO10QBAS47boO5cV2yyFD8-IN7Np8sMKvfWHWH3?key=bjRmQ1dqSHJHcE5JeGVNaVl3S1FIc m9yRmpwOFVB
    Nice! I'm going to figure out the routing when the time comes, same with my SW20 shifter that I should have next week. The shifter will be getting disassembled, blasted and coated...unless my buddy hooked me up like he said he was.
