The Wiwood pedal box assembly does not take into account the Factory Five mounting bracket that mounts between the Wilwood pedal assembly and the master cyclindars.
The Wilwood factory installed studs are too short. Even if you do not use the washers provided the nylock hex nuts do not come close to seating properly. I would say the studs are approx. 1/4" short if you use the FFR supplied washer and grade 8 nylock hex nuts.
Removing the studs is a complete pain. They are factory installed with locktite red. I applied heat to the stud and jammed two nuts together on the stud in order to remove them with a wrench. I guess you can use a vice grip wrench but that seemed a little cave man.
I spent the afternoon trying to find grade 8 studs ( 5/16-24 ) in the proper length to replace the ones in the wilwood box. Can not find them anywhere.
Is there a specific reason for grade 8 hardware? I found 5/16-24 threaded rod but it is not rated. The only other option is to buy 2" fully threaded bolts from McMastercarr. $36 for two packages of 5. Only need 6.
