Results 1 to 3 of 3
Thread: coyote VIN location
    Feb 2017
    coyote VIN location
    Installing a 2011 F150 version in my mk4.
    I keep reading about the states inspector wanting to see the engine VIN and proof of purchase (aka not stolen)
    Anyone know where it is located on the block?
    Greg
    Ang's 33 HRC amasciarelli21's Avatar
    Jul 2012
    New Jersey
    Hi Greg, serial number for block is on passenger side head just above the third header tube from the frt. ( # 6 cyl. I believe). I have the same engine and had to stencil the number, not easy but doable.
    Ang
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    Engine serial no. for Coyote is also located on a sticker at the rear of the engine under the drivers side coil cover.
    just pull the coil cover and wa-la there it is.
    Nevin
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
