Results 1 to 30 of 30
Thread: Cruise Control
    Aug 2012
    Long Island
    Cruise Control
    Any 818S guys planning on installing cruise control? The DBW guys should have it pretty easy, and for DBC, l was looking at the modules and they shouldnt be too hard to hide somewhere. I don't think i'll be installing on mine, but for those that plan on it, do you think it will be too twitchy with such a light car?
    Mechie3's Avatar
    Indianapolis
    I'll install it, since my car is DBW. If it's too twitchy, I can just remove the lever on the steering wheel. I wonder if the cruise is adaptive? In my 06, most of the time I used cruise, it wouldn't engage boost unless I was going up a steep hill. In the 818, without boost, it might not be too bad.
    Zero Decibel Motorsports
    Check out my new website!
    Senior Member VD2021's Avatar
    Central, FL
    Wouldn't build an "S" it without it. Even if I had to settle for an aftermarket system.
    "twitchy" ? Are you asking if it will be able to maintain vehicle speed within a certain tolerance?
    I expect it to operate just as it does in the donor. Less vehicle weight will decrease the systems work load so it should work as expected.
    To keep the install as simple as possible, during tear-down of the donor keep the ENTIRE SYSTEM INTACT. There will likely be a requirement to extend wires or make other minor modifications from the systems original state to complete the install. But If you can keep it as close to plug-and-play as possible you should have trouble free operation.
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Aug 2012
    Long Island
    twitchy meaning the throttle modulation is calibrated for a 3600lb car, so when cruise control activates, I imagine the car will accelerate much faster than intended, when the speed sensor sees the increase it will slam the throttle shut. On my modified 05 the cruise comes on very strong especially under load. I imagine it will be more pronounced on the lighter 818, but that's just a guess.
    Mechie3's Avatar
    Indianapolis
    ^^ That was my thought. I just hope that since it doesn't usually go into boost, it won't be OMG THROTTLE with the rear wheels breaking free just a bit more than you're used to, but nothing uncontrollable or violent.
    Central, FL
    Not planning to do HP mods so that increases the chances it will function with in an acceptable tolerance.
    I'll know how it functions (good or bad) when I hit that stage in the build.
    R/s
    Vidal
    Exeter R.I
    Absolutely not, and prob no abs either. My 818 will have a radio, heat/ac, and that's about it.
    Senior Member PhyrraM's Avatar
    Considering all the "proper" donors had it, it would likely be just as much work to remove it than to keep it. The controls are already on the steering wheel.
    On the 2.0 liter cable throttle cars all you would need to do is mount the actuator in the engine bay and plug it back in. On the 2.5 liter drive-by-wire cars all you need to do is plug everything back in.
    Weight savings is virtually nothing. A few OZ for the wheel controls and maybe 1/2 pound for the actuator on cable throttle cars.
    Livonia, Michigan
    I am planning to have cruise on my 818, for those long boring drives to the local track (Mid-Ohio). The funny thing is that on my 2002 wagon donor, it is the only thing that doesn't work. If any one is planning to not use the cruise control, PM me so I can buy your cruise control parts to get mine working again.
    Exeter R.I
    i will sell it to you
    QC, Canada
    Great, that's the info I was looking for. Search function is sometimes useful.
    Hopefully those who will install cruise control will post here.
    Like VD2021.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Freeport, ME
    Cruise is essential for my street car... sometimes you just have to take the highway.
    As far as weight and how it works... should be fine, consider a truck full or empty, even my 1/2 ton goes from 5000 to 6500 lbs loaded and the cruise works either way.
    Member Hiryu's Avatar
    My Murtaya has cruise control on it, and when it engages it does seem to get up to speed a bit quicker than a normal STi would, but it's not too bad, especially if it's just maintaining speed and not 'catching up'. I drove it for over 1000 miles from Denver to Seattle and I had no issues with the CC.
    Now keep in mind the Murtaya is probably a few hundred pounds heavier than the 818 is projected to be and is still AWD, but I don't think you will be put off too much by the behavior of the cruise control in a lighter car.
    The bigger issue might be (at least it was for me): where are you going to mount the controls? If you use the stock wheel, you will be good, but I'm guessing a stock steering wheel will be far too big for this car (it was for mine). I'd suggest looking at a Prova or GTSPEC D-shaped rim replacement (they keeps the center of the wheel, cruise control, etc., and replace the wheel rim with smaller, thicker wheels). If you go with a full aftermarket wheel--especially a removable one--you might have to mount the controls elsewhere...
    QC, Canada
    I'm pretty sure the ISIS system can control all that from the touch screen (for those using ISIS), they claim you can ask them to configure anything you want. As long as the cruise control hardware and wires are connected to the ISIS control board, of course.
    There seems to be some universal controls as well, for which you can have a bunch of switches, even dash mounted buttons. http://www.rostra.com/aftermarket-cr...-by-rostra.php
    Any updates on this at all? Anyone running the DBW cruise control with an external mount control? Looking to run an aftermarket steering wheel but maintain cruise.
    Senior Member AZPete's Avatar
    Quote Originally Posted by STimedic View Post
    STimedic, I'm using the WRX DBW cruise control with the Factory Five steering wheel, which would be the same for any Momo-type wheel. I cut and bent the steel piece under the steering column so I could mount the cruise control lever. After cutting some of the plastic column shroud the lever is easy to reach down near the dash. It works very nicely with all the OE controls - set, resume, etc. - and is not "twitchy" as some thought, but works just like the OE cruise control. If these photos don't make sense let me know.
    I am wondering if I can simplify the cruise control to just have one toggle in the wiring which would be the "set" feature. I have an 03 wiring harness and it looks like all I would have to do would be to put a switch between the RG and LgB wires for me to be able to set a speed. I am assuming that the brake and clutch cancelling mechanisms would be un affected. If anyone has any expertise in doing so that would be very handy.
    AZPete, brilliant! I'll be using a Sparco Prodrive steering wheel and short hub, so this would be worthwhile.
    Nov 2015
    Caledon, Ontario
    A question for you wiring wizards. I would assume that the wheel speed sensors (ABS) are required for the cruise control to function. Is it possible to get it working with only one or two sensors? We are not close to wiring yet, but just thinking ahead. We've blocked the front holes off already with the plates we bought from Craig, and then I saw this thread. I always use cruise in other vehicles. I find that it helps lower the amount of speeding tickets, lol!
    I am not wiring wizard as you can tell from my previous question... but as far as I understand for MY 2002-2004 the vehichle speed sensor is in the manual transmission so you do not need the ABS rings or sensors. i believe they removed the speed sensor from the transmission in 2008+ model years. IMG_3040.PNG
    Nov 2015
    Caledon, Ontario
    Quote Originally Posted by iblackwe View Post
    Thanks. Our donor is an '05, so I think we'll be good.
    Freeport, ME
    Quote Originally Posted by THE FURNACE View Post
    Not required, wine works great, no tone rings on the car.
    Dan
    . . . , wine works great, .. .
    LOL, I agree, Dan.
    Freeport, ME
    OOPs mine works great
    Dan
    Denver, CO
    You should be good unless you upgrade to STI or legacy trans, then you need the sensors and a module for the VSS wire
    Nov 2015
    Caledon, Ontario
    Thanks bbjones. I think I'll stick with this transmission unless
    it grenades. I'm still debating on an LSD, and kind of leaning towards installing one.
    Does anyone know if I have wired this correctly without the original cruise control switch and just a momentary on/off rocker for the "set" feature. I am about to button the dash up and if anyone has any suggestions prior to me finding out by trial and error that would be much appreciated!
    Mar 2017
    West Phoenix
    Got mine mounted and my impression is that I would win any cruise control race.
    Although with that said, it's not hard to use and it does boost on accel.
    I started using it on long drives and it's easy to use on street if you leave enough room between cars.
    NYC
    Where I live, I can't use cruise control on the highway even if I wanted to. Too many damn cars.
    Freeport, ME
    Where I live you can cruise control on secondary roads... Moderate sized State, only 1.3 million people, most living in the lower 1/3 of the State. Love the low population density.
    Dan
